Create Acrobat comment in InDesign
I prepare a large document in InDesign, and then export it as a PDF for distribution. I’d like to be able to insert comments while in InDesign, so the reader can choose whether or not to print the comments when they print the PDF document. I export multiple versions of the same InDesign document (using different linked files for each version), so I don’t want to have to repeatedly insert the same comments via Acrobat in each version.
Anybody have any ideas for doing this?
chartguy
