Activity Forums Apple Final Cut Pro Legacy create a sequence with exact settings of a clip
  • create a sequence with exact settings of a clip
    Posted by Accountclosedduetonorealnameused on October 10, 2006 at 4:35 pm
    Often I use source clips that I bring into FCP and want to edit natively, without having to render.
    Problem is, if I created a sequence and one setting in the sequence is different from the source clip, the clips will not play down in the sequence before rendering.
    Is there a way to created a sequence based on all the various parameters of a source clip?
    Ron James replied 19 years, 11 months ago 2 Members · 1 Reply
  • Ron James
    October 10, 2006 at 9:48 pm
    I think the trick to this is to highlight the clip, then right-click and select ‘make multiclip sequence’ and make sure the option to automatically create a sequence is selected. This should create a sequence with your clip in it and the settings should match.
    I’m not at FCP right now, but I think that’s right.
