Activity Forums Boris FX Create a perfect rounded cube in Red5
  • Create a perfect rounded cube in Red5
    Posted by Neil Adamson on June 16, 2011 at 8:07 pm
    Hello
    I am struggling to create a rounded cube in Boris red –
    I would like to create a spinning rounded cube (dice) with numbers on it.
    When I create a cube it assumes the full size of the video canvass which is a 16:9 canvas and I struggle to get it to the perfect size – i.e square all round, and if I can manage this, how to round out the edges?
    Anyone know of any tutorials to do this?
    Neil
    Neil
    Effective Video
    http://www.effectivevideo.co.za
    Theo Van laar replied 15 years, 3 months ago 4 Members · 3 Replies
  • Boris Yamnitsky
    June 16, 2011 at 9:10 pm
    the cube is stretched to match video aspect ratio so that you can map a whole frame on it’s side without distorting the image. To make a perfectly square cube you need to do some math and scale X and Z dimentions to match the Y dimension. In your case I beleive the magic number is 56.25%
    Hope this helps.
    Boris Yamnitsky
    BorisFX
  • John Rofrano
    June 17, 2011 at 5:55 pm
    If you are looking to make dice, you could create a project that is 512 by 512 and import images for the face of your dice / cube that are 512 x 512 and everything will fit perfectly.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Theo Van laar
    June 18, 2011 at 4:38 pm
    Creating the dice with 6 square sites will be no problem. But Neil is also asking how to make the corners round just like a real dice. I have been puzzling with this problem for quit some time, but I never found the solution. But I’m sure John can explain it to us?
    Theo
