Activity › Forums › Adobe After Effects › Create a particular text animator.
  • Create a particular text animator.
    Posted by Andrei Popa on January 27, 2024 at 5:18 pm
    Hi guys.
    I really need to replicate this text animation, and using multiple layers is not an option.
    I tried using a text animator based on position with various offset values and shapes (from the advanced selector submenu) but to no avail. All the animations either don’t come back to the starting position, or are stiff and the animation happens on each row separate. As you can see, in this animation the row animation overlaps a little.
    Thanks in advance for any solution/guidance toward a solution.
    Andrei Popa replied 2 years, 8 months ago 1 Member · 1 Reply
  • Andrei Popa
    January 27, 2024 at 5:48 pm
    I managed to pull this off.
    I did 4 animators, for each direction. one positive value, one negative etc.
    I have set the shape to all to Ramp Down and I have put keyframes on Offset from -100 to +100. Each Offset -100 keyframe was positioned on the +100 keyframe from the previous one.
