Activity Forums Apple Final Cut Pro Legacy Create a new sequence
  • Create a new sequence
    Posted by Eric Holzapfel on July 7, 2008 at 12:37 am
    Hello Members,
    I have searched around for the answer to my question before placing on this forum. I have not found the answer. Hence, my post.
    I have learned that using “Easy Setup” project settings can be defined that will apply to the NEXT project I open. OK.
    My question: Can I open an existing project (or even an “untitled”) and add a new sequence, say a 24p sequence (HV20, 1080i compressed clips) to a project that has a sequence in it already? Like the orig capture from my HV20, at 1080i/60p.
    What I have been doing is opening FCP, and using the “Easy Setup”, and changing settings to what I think I need, and then closing the “untitled” project, and opening up a new project with the settings I set using the easy setup process.
    Thanks for your forum,
    Eric
    Eric Holzapfel replied 18 years, 1 month ago 2 Members · 2 Replies
  • Boyd Mccollum
    July 7, 2008 at 1:31 am
    [Eric Holzapfel] “What I have been doing is opening FCP, and using the “Easy Setup”, and changing settings to what I think I need, and then closing the “untitled” project, and opening up a new project with the settings I set using the easy setup process. “
    You can have multiple sequences in one project with different settings. Cmd+N creates a new sequence. Select the sequence in the browser (before opening in the timeline) and Cmd+0 opens the Settings dialogue box. Change settings to whatever you need. NOTE: once you open the sequence in the timeline you won’t be able to change the timebase. So if that’s important, do it first.
  • Eric Holzapfel
    July 7, 2008 at 7:23 pm
    Hello,
    Again Thanks for the information. Maybe one day I will be familiar enough to provide answers to questions, instead of asking questions!
    eric
