Activity Forums Adobe After Effects create a “light from tv” effect
  • create a “light from tv” effect
    Posted by Digiwomen on November 18, 2005 at 5:11 pm
    ok, two actors on a couch, talking about the movie they are “watching” . How do I create a “light from tv” falling over the actors effect? thx
    Todd Gillespie replied 20 years, 10 months ago 3 Members · 2 Replies
  • Enzo Tedeschi
    November 18, 2005 at 9:44 pm
    Off the top of my head (without doing any noodling), I’d say try creating a solid layer with feathered edges (to create a falloff of light), stick it on a layer above the couch footage, and then play with your composite modes (soft light, luminance etc…), depending on your footage, you may find one of these helpful.
    Then again, maybe not…
    :o)
    e.
  • Todd Gillespie
    November 19, 2005 at 12:16 am
    Enzo had a good point that you are going to need to play around with the composite modes. This will help to shape the light. Otherwise AE is going to add light to the entire frame of video. If you had done the light on location, you would notice that the tv light will be brighter is some areas and fall off in others. If you just add a light from AE, it’s not going to understand how to mold the light around your people.
    Good Luck,
    Todd at UCSB
    Television Production
