Activity Forums Adobe After Effects Create a Jigsaw Puzzle
  • Create a Jigsaw Puzzle
    Posted by Paulo Mateus on June 10, 2007 at 11:09 am
    Hello
    I’m trying to create and animate a Jigsaw Puzzle in AE. I have to make many, so I’m trying to find the fastest way to do it.
    I tried with Shatter and it really creates a nice Jigsaw Puzzle but I can’t make the pieces freezing and animate them separately, you know, animate the building of a puzzle and not explode it.
    Any ideias?
    Paulo
    Paulo Mateus replied 19 years, 3 months ago 5 Members · 6 Replies
  • Julian Sixx
    June 10, 2007 at 12:09 pm
    Hi
    i’d create the puzzle in Photoshop with a Action and animate it in AE
    https://www.adobe.com/cfusion/exchange/index.cfm?cat=190&l=-1&event=productHome&exc=16&Submit=Filter
  • Rhett Robinson
    June 10, 2007 at 2:01 pm
    If you make a custom shatter map (basically just puzzle pieces), animate it in shatter as you’d like (probably no gravity, etc depending on the look you want), then precomp or put it in a second comp and reverse the time, use time remapping, etc. I’ve also done it the hard way (which wasn’t too bad), and split a photo into 30 pieces or so using a puzzle piece map to make a custom selection each time and make a separate layer in photoshop for each piece. Then, import as a composition into after effects. When all the layers are stacked, the puzzle is whole. What I liked about it was the ability to give each piece a better bevel/lighting. What I liked about shatter with a single photo was the ease with which a little depth is available. Also, with shatter, you could build it once until your’re happy, then duplicate your comp, replace the map and the photo by dragging, adjust a few settings. I bet you could burn through 30+ photos an hour, after doing the first 15 minute setup!
  • Rhett Robinson
    June 10, 2007 at 2:06 pm
    Man – hadn’t been there in a long time! I found lots of great stuff in a hurry! – Thanks for the reminder.
  • Roland R. kahlenberg
    June 10, 2007 at 2:08 pm
    With Shatter, you can change the Repetition parameter and get more or less pieces easily – great if you need to set up lots of puzzles with different sized/number of pieces. Use a gradient map to selectively choose which pieces get shattered through sequentially. Time Remap accordingly (if required) to have better control over the motion of the pieces.
    HTH
    Roland Kahlenberg
    https://www.broadcastGEMs.com – Adobe After Effects project files
    https://www.myspace.com/rorkrgbspace
  • Cathy Ralph
    June 10, 2007 at 10:50 pm
    Don’t know if this would be helpful, but https://www.avbros.com/ makes a great plug-in called Puzzle Pro 2.0
    Good Luck!
    -Cathy
  • Paulo Mateus
    June 12, 2007 at 11:38 am
    Thank you all for your great help!
    Paulo Mateus
