Activity Forums Maxon Cinema 4D Create a Jacob’s ladder flip animation
  • Create a Jacob’s ladder flip animation
    Posted by Ryan Ainge on August 25, 2011 at 6:05 pm
    Trying to figure out how to create a flip like this.
    I can do all the movement manually, but I feel like there is a mograph effector I could use to achieve this much more easily. I’ve tried shader and step, but I couldn’t get it to work.
    Here’s my file:
    https://www.mediafire.com/?nz7d24o32d6nr52
    Basically my file has everything I want except the jiggle between each flip and I can’t get that effect since they are all children of the main plank. I tried to add the delay effector for that, but couldn’t get it to work without a mograph object.
    Any help would be awesome. But searching for a preferably non-dynamic solution.
    Ryan Ainge replied 15 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    August 25, 2011 at 8:56 pm
    I know you’d rather avoid dynamics, but that would give you the most realistic result: 2851_jacobsladder.c4d.zip
    Otherwise you could try the constraint tag’s spring constraint, but I haven’t had much luck with that.
    Or you could use joints and IK dynamics.
  • Ryan Ainge
    August 25, 2011 at 9:48 pm
    Great, thank you very much Adam
