Activity › Forums › Adobe After Effects › Create a 3D stroke from a null object
  • Create a 3D stroke from a null object
    Posted by Davide Mitidieri on November 20, 2016 at 8:50 pm
    Hi everybody,
    I’m trying to make a 3D map animation.
    Up to now, the map is a 3D layer which contains a jpeg of the map (so, it is flat, but it can spin around 3 axis). Later on I’ll add the 3D terrain with Element 3D.
    But that is not the problem. I’m trying to create a path which has to start at a certain time, and finish at another time. When I worked on 2D maps (still in 3D layers), it was easy because I could simply create a shape layer and add a trim path to it, then parent the path to the map.
    Now, I don’t know how to create a 3D path! I’ve read it is possible to parent a layer to a null object position, so that layer moves along a 3D path. Similarly, Is there a way to generate a stroke from the position of a null object?
    If not, are there other ways to achieve this?
    There is an example (the orange curve is just the 3D position of the null layer):
    Roei Tzoref replied 9 years, 10 months ago 3 Members · 5 Replies
  • Roei Tzoref
    November 21, 2016 at 12:04 am
    unless you are you going to move the camera in perspective and want to simulate that the stroke is not flat, I think a flat 3d path should be enough. but if so maybe this will help: you can use BAO Mask Avenger script: https://aescripts.com/bao-mask-avenger/ to generate nulls from shape/mask vertices in 3D
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Daniel Waldron
    November 21, 2016 at 6:59 pm
    You could use Trapcode Particular. CC Particle world might also work, but would be a bit tricker.
  • Davide Mitidieri
    November 21, 2016 at 7:22 pm
    The map is going to move and rotate, so a 3D flat path would be enough. Furthermore, the path is going to track mountain footpaths, so the altitude can vary a lot and a flat path would not be suitable for that purpose…
  • Davide Mitidieri
    November 21, 2016 at 7:24 pm
    However, I didn’t understand the shape/mask vertices in 3D…. is it possible to create a 3D mask of a layer? In that case, would be possible to apply the effect “Generate > Stroke”?
  • Roei Tzoref
    November 21, 2016 at 9:27 pm
    [Davide Mitidieri] “e map is going to move and rotate, so a 3D flat path would be enough. Furthermore, the path is going to track mountain footpaths, so the altitude can vary a lot and a flat path would not be suitable for that purpose…”
    couldn’t you just make the path flat 3d and fake where there is altitude?
    [Davide Mitidieri] ” is it possible to create a 3D mask of a layer? “
    in you mean that the path is in true 3D space – you will need a plugin or script for that. the one I showed you does enable the path to be manipulated in 3D space.
    Roei Tzoref
