Activity › Forums › Adobe After Effects › Create a 3D box with Opening Lids
Posted by Tim Dill on September 16, 2011 at 7:24 pmI am trying to create and animate a 3D box and animate the lids opening as well in After Effects. I seem to be finding all kinds of tuts about animating 3D boxes but none that animate the lids opening.
Can this be done and if so how would I do this?
Thanks in advance!
Tudor “ted” jelescu replied 14 years, 11 months ago 3 Members · 3 Replies -
Ben G unguren
September 16, 2011 at 7:56 pmMove the anchor point of your “lid” to the edge, where the hinge would be. Then animate that layer’s rotation. Voila: the lid lifts….
If you want more complex box-opening animations, is’t mostly a matter of parenting the proper layer to other layers, setting your anchor points in the proper location, and animating their rotations….
Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tim Dill
September 16, 2011 at 8:16 pmAlright, I have tired this and it kind of worked but it only looks like the lid is opening half way, almost to vanishing point to where it goes into the flip. I am having trouble getting it skewed so it looks like it has opened all the way and the other lid I can’t even get it to work at all. Can you apply for than one anchor point to one shape layor? If so, how?
Also, I have never used ‘Parents’ before, which means I have no idea how to use them. Can you recommend where I can find out how to use these?
Tudor “ted” jelescu
September 17, 2011 at 10:06 amHere’s a couple of useful links for parenting:
https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7da0a.html
https://library.creativecow.net/articles/ebberts_dan/expressions.php
Tudor “Ted” Jelescu
Senior VFX Artist
