Activity Forums Compression Techniques Create a 16-channel Audio Stream?
  • Create a 16-channel Audio Stream?
    Posted by Jason Douglas on February 1, 2014 at 7:10 am
    Could someone shed some light on creating a video file containing a stereo/2-channel audio stream into a new file with 16-channel stream? The destination is a DNxHD with pcm_s24le audio. I have tried every commandline argument I can find and they are either outdated or error out instead of creating additional channels… I was able to do it somewhat with ffmbc, but it would crash with %80 of my files.
    I am attempting to author files for playback on a hyperdeck. I have managed to create uncompressed v210 files that playback fine. I am trying to DNxHD to reduce file size and increase the length of clips I can fit on 256Gig SSDs… the files I have created play video fine, but I definitely need to match the audio format to have a hope for it working.
    I have been using FFmpeg with much success lately, but I have found plenty of reference on splitting a single 16-channel stream into seperate streams, but not how to create a 16-channel stream. Ideally, 0=0, 1=1, 2-15 muted… Thank you in advance for any insight offered!
    Jason Douglas replied 12 years, 7 months ago 4 Members · 6 Replies
  • Stephen Dixon
    February 2, 2014 at 10:45 am
    I think you may need to do it in two passes. First create a file with all the audio as separate streams, and then use that as the input to the next pass, where you can use the amerge filter to merge them into a single multi-channel stream.
    https://ffmpeg.org/ffmpeg-filters.html#amerge and https://trac.ffmpeg.org/wiki/AudioChannelManipulation might be helpful.
    Stephen Dixon
    Editor, Animator, Motionographer
    Museum Victoria
  • Lou Logan
    February 2, 2014 at 7:55 pm
    [Jason Douglas] “how to create a 16-channel stream. Ideally, 0=0, 1=1, 2-15 muted…”
    I don’t really understand. Why do you need 16-channels? Where is the audio data coming from for the 2-15 channels? Or do you just want to generate silent audio?
  • Jason Douglas
    February 4, 2014 at 3:50 am
    I will try the multi-pass.
    In order for the Blackmagic Hyperdeck to recognize a clip, it must mee the exact standard for playback. If it isn’t a 16-channel 24-bit LPCM stream, it won’t play it… Thanks Blackmagic…
  • Jason Douglas
    February 4, 2014 at 6:43 am
    I was able to create a 16-channel stream with:
    ffmpeg -i wildlife.wmv -c:v dnxhd -b:v 185M -r 29.97 -s 1920x1080 -flags +ildct -filter_complex "[0:a][0:a][0:a][0:a][0:a][0:a][0:a][0:a] amerge=inputs=8" -c:a pcm_s24le -ar 48k output.mov
    The ffprobe of the resulting file shows: 16 Channels (FL+FR+FC+LFE+BL+BR+FLC+FRC+BC+SL+SR+TC+TFL+TFC+TFR+TBL)… Is it possible to assign a channel map of 16 mono channels or no map at all?
  • Reuben Martin
    February 5, 2014 at 3:22 am
    I believe the channel mapping is assumed (although I may be wrong).
    Are you sure the Hyperdeck needs a single audio stream with 16 channels? Most hardware I’ve run into uses 16 separate audio streams with a single channel each.
  • Jason Douglas
    February 5, 2014 at 4:12 am
    I have recorded test files in the various formats supported by the hyperdeck. Prores has been a block wall. Black magic uses their own implementation that makes it impossible to author correct files with ffmpeg.
    DNxHD in mxf wrapper uses a 24 bit linear pcm 16-channel stream. This is what I am trying to create.
    I know DNxHD in an move wrapper creates 3 files: 1 video and 2 audio. I haven’t analyzed those files yet, but will tonight as an alternative.
