Activity Forums VEGAS Pro Create 3D zoom from 2D picture?
  • Create 3D zoom from 2D picture?
    Posted by Sorin Amzu on August 1, 2010 at 7:54 pm
    Basicly, how does one create this effect: https://vimeo.com/3936146 in sony vegas? I’ve seen an after effects tutorial, but am really close to getting it in vegas.
    Thanks.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Sorin Amzu replied 16 years, 1 month ago 2 Members · 2 Replies
  • John Rofrano
    August 2, 2010 at 11:58 am
    You do it exactly the same way you would do it in After Effects. You cut the picture up into layers with Photoshop. If you have Vegas Pro 9.0, you right-click and drop the Photoshop PSD file onto the Vegas timeline and select Add Across Tracks. Finally, you turn on 3D Track Motion for all of the tracks and position them in 3D space.
    If you don’t have Vegas Pro 9.0 then you need to export the Photoshop layers as individual PNG files with an alpha channel transparency and place each one on a Vegas track.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Sorin Amzu
    August 2, 2010 at 2:21 pm
    Thanks for the input. Got 2 tracks, one for a person in front of a second track which is the background. Problem is right now it just looks as if i’m zooming into the background layer. Also the 3d source alpha doesn’t help, as the zooming doesn’t look 3d 🙁
    If there’s any video tutorial you could point me to, I’d be grateful.
    Let me include some of my tests:
    https://www.mediafire.com/?48k6b6wq72t31d7
    https://www.mediafire.com/?6m178suix3c6veo
    https://www.mediafire.com/?m4psn8l6jrn3a34
    I don’t know if I should move the sky as well. If so, at what rate?
    Thanks.
