Activity Forums Zaxwerks Create 3D Primitive: Sphere Only?
  • Create 3D Primitive: Sphere Only?
    Posted by Don Gray on June 6, 2005 at 11:09 am
    Like I mentioned previously, I am new to Zaxwerks and Invigorator Pro for AE.
    I’m still waiting for the manual to come in the mail.
    I have looked around in the various help dialogs but haven’t seen anything related so I’ll ask here,
    when creating a 3D object, the sphere is the only option. I assume(?) there are more somewhere?
    Otherwise the dialog would read “create 3D sphere” I would guess.
    Where are these hidden primitives located?
    While I’m at it is the Set Track 3D Layer option so you can use a 3D layer without AE telling you
    not to set the regular Invigorator layer to 3D while using an AE camera?
    Or as in my lighting/shadow post, is this layer where I put my 3D comp lights?
    Off to try some of these things out.
    Don
    Don Gray replied 21 years, 2 months ago 2 Members · 2 Replies
  • Marcelo Lewin
    June 6, 2005 at 4:10 pm
    I can answer two of your questions:
    1) The book is in the zip file. It’s a PDF. It’s about 70 pages. I printed it. It’s a really good book.
    2) Re: Spheres only. Click on the Object tag. You will see there a pull down for the different types of primitives.
    Hope this helps!
    Marcelo Lewin
    marcelo@thedailyfarce.com
    https://www.thedailyfarce.com/
  • Don Gray
    June 6, 2005 at 4:56 pm
    Oh, cool, thanks Marcelo!
    I did find the object tab to change the object type and I’ll take a look at the PDF.
    Don
