Activity › Forums › Apple Final Cut Pro Legacy › Create 16:9 from 4:3 ( Yes, I know… ) FCP Plugin ?
Posted by Mistertones on February 17, 2006 at 12:24 pmHi All,
We are going to be working on an independent film release which was shot on 4:3 cameras and then had black bars added to create a 16:9 effect. ( Sigh… )
The customers would like this scaled up to genuine 16:9 anamorphic for the film release.
Currently I’m experimenting with VirtualDub & AVISynth, but wondered if there was a really good scaling plugin for FCP that anyone would recommend ?
Thanks for any ideas,
Cheers
Ian
Mistertones replied 20 years, 7 months ago 4 Members · 8 Replies -
Arnie Schlissel
February 17, 2006 at 4:09 pmWhat version of FCP? The scaling in v5 is soooo much better than previous versions, that I’d just do it in FCP. If you’ve got a previous version, then you might be better off doing this in AE or Combustion.
Arnie
https://www.arniepix.com -
Mistertones
February 17, 2006 at 4:42 pmInteresting, thanks – we are on 4.5 at the moment. So, unless we get AE we’re stuck until the Universal upgrades become available in March, am I right ?
David Roth weiss
February 17, 2006 at 4:46 pmThe normal technique in FCP (when using a full-frame 4×3 original) is to create a 16×9 anamorphic timeline, drop your sequence in, and scale up until you fill the frame. Using full frame 4×3, that nomally means sacling up 33%. Since you cheated, you may have to scale up slightly more to completely lose you phony letterbox on the top and bottom. The results are actually pretty stunning.
DRW
Arnie Schlissel
February 17, 2006 at 5:06 pmNot necessarily. Run a test using the method DRW describes below to a short segment of your timeline. Output as you were planning & check the quality. It may be ‘good enough’, in which case, you’re ‘golden’.
Arnie
Peter Wiggins
February 17, 2006 at 11:40 pmBut then you can’t move the clips up or down so you don’t cut off heads etc.
If you have the original sequence, make a duplicate then change the propeties to anamorphic.
Blowup all the clips to 133% (you can paste attributes here) and then watch through, stop when you have to move a clip & if you use the wireframe, hold shift down so you don’t get any X movement and make sure you stop the Y offset at a ‘whole’ number.I think thats it 🙂
Peter
David Roth weiss
February 18, 2006 at 2:43 amPeter,
If he’s already letterboxed the whole movie by masking top and bottom one would assume he’s already repositioned every shot, and if not, it would be too late now…
DRW
Mistertones
February 20, 2006 at 11:13 pmDavid hit the nail – its already been letterboxed by someone else.
Mistertones
February 20, 2006 at 11:18 pmThanks, but I’m looking for “the best possible without going insane” rather than just “good enough”. One suggestion was to use something like this:
https://www.benvista.com/main/content/content.php?page=ourproducts§ion=photozoompro_1
– which looks like a good option, although I’d need to de-interlace to 50p using FieldsKit or similar, then re-interlace to 50i again.
Any other suggestions ?
