Activity Forums Adobe After Effects Creasing an Image
  • Creasing an Image
    Posted by Msobetzko on May 10, 2006 at 2:25 am
    I’m working on a DVD menu and I am trying to simulate a childrens pop up book in which cardboard looking images “unfold” as the menu opens. My main problem is getting the look of the image crease at the bottom plane of the menu. I would like the image to look to be folded and attached to the bottom of the menu.
    Suggestions?
    Mike
    Tony Kloiber replied 20 years, 4 months ago 2 Members · 1 Reply
  • Tony Kloiber
    May 10, 2006 at 1:28 pm
    For the crease you might try a displacement map (mostly black with a thin gray to white line) used to wrinkle the image. For the unfolding there are some distortion plugins but you might also look at animating two copies of the image one on ether side of the fold as 3D layers.
    TonyTony
