Activity › Forums › Adobe Premiere Pro › Crazy Export Times!
  • Crazy Export Times!
    Posted by Katya Szewczuk on February 15, 2018 at 11:05 pm
    Hey everyone! Okay, so I cleared cache, I rendered my project and yet my entire project is taking about 10 hours to export. The footage is 4K with effects added to it and the audio is a separate file. It’s a 45 minute piece and normally it would only take 2-3 hours to export. I was supposed to get this video up today, but looks like I’ll have to wait a day or two to get it up unless it’s an easy fix.
    I am using Premiere Pro CC. Is it an update issue? Or could it be my hardware? Thanks!
    Greg Janza replied 8 years, 7 months ago 5 Members · 6 Replies
  • Tero Ahlfors
    February 16, 2018 at 5:04 am
    What are your system specs/sequence settings/exact export settings?
  • Todd Perchert
    February 16, 2018 at 3:07 pm
    And what effects are added to the video?
  • Chris Wright
    February 16, 2018 at 9:34 pm
    doing a 2nd pass with noise reduction separate from lumetri often helps
  • Greg Janza
    February 16, 2018 at 10:07 pm
    there’s no way to help you if you don’t say what your system specs are.
    I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
    – Orson Welles
  • Katya Szewczuk
    February 17, 2018 at 11:46 pm
    Here are my specs!
    OS Name Microsoft Windows 10 Home
    Version 10.0.16299 Build 16299
    Other OS Description Not Available
    OS Manufacturer Microsoft Corporation
    System Manufacturer HP
    System Model 750-435st
    System Type x64-based PC
    Processor Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz, 3408 Mhz, 4 Core(s), 8 Logical Processor(s)
    BIOS Version/Date AMI F.14, 9/19/2016
    SMBIOS Version 2.8
    Embedded Controller Version 255.255
    BIOS Mode UEFI
    BaseBoard Manufacturer HP
    BaseBoard Model Not Available
    BaseBoard Name Base Board
    Platform Role Desktop
    Secure Boot State On
    Installed Physical Memory (RAM) 16.0 GB
    Total Physical Memory 16.0 GB
    Available Physical Memory 6.93 GB
    Total Virtual Memory 38.0 GB
    Available Virtual Memory 17.4 GB
    For Premiere I’m using Premiere Pro CC and have been exporting with H.264 format with the Match Source High Birate Preset (as requested). There’s also a message that says, “Rendering required Audio Files” whenever I use this preset.
  • Greg Janza
    February 18, 2018 at 6:18 pm
    what GPU is in your system? and where are you saving this file to? what type of media drive?
    One issue is that you don’t have enough RAM. You need 32 gigs minimum for 4k editing.
    – Orson Welles
