Activity › Forums › DaVinci Resolve › Crashing on XML export 9.0.4
Posted by Chad Terpstra on December 18, 2012 at 9:01 amI’ve got a sequence I’ve rendered and am trying to export an XML of but it crashes every time. It happens right after the filename dialogue box. I’m on 9.0.4 and have tried exporting the project and reimporting it. Media is Red 5K with lots of speed effects (some over 4000%). Any ideas? You’d think these bugs would have been ironed out by now.
Chad Terpstra replied 13 years, 9 months ago 2 Members · 8 Replies -
Simon Blackledge
December 18, 2012 at 9:23 amAll I can suggest is make a new timeline.
Remove all speed change clips and try an exportIf works is a speed change issue.
Then find any clips with large retime % ie 4000 and try just exporting that to see if it crashes.
Chad Terpstra
December 18, 2012 at 9:29 amThanks Simon. I’ve already started doing what you’re suggesting by breaking the sequence into chunks. The first chunk went through fine but the second and third crashed. It’s only a 2 minute piece but lots of fast cuts and tons of speed changes. I’d basically have to go every three clips at this point. Very frustrating.
Chad Terpstra
December 18, 2012 at 9:52 amYes, render is A-OK. XML export cause crash. I managed to export an EDL but the media is offline so I’m re-rendering and trying that again.
Simon Blackledge
December 18, 2012 at 10:17 amDo you really need to render out as separate files over a single final render?
Chad Terpstra
December 18, 2012 at 4:42 pmI’m not sure what you mean. Is there a way to render out a flattened sequence?
Chad Terpstra
December 20, 2012 at 4:27 pmVery nice! I hadn’t seen that option before. Great option to have as a backup for these situations. It saved the day. Thanks!
