Activity Forums Adobe After Effects Expressions Crashing on render
  • Crashing on render
    Posted by William Mcquay on September 25, 2006 at 1:12 am
    I’ve been try to render some effects intensive layers within a moderately sized AE 6.5 comp and my MAC G5 Dual 2 Gig crashes about a quarter of the way through the renders, and I’ve tried quite a few.
    A couple of things confuse me. First the render window says I’ve got 2047 MB of RAM when I’ve got 4.5 Gigs of RAM installed. Second, thinking the crashes may be memory related I turned on the Disk Cache but still, the system crashes.
    I’ve never had this problem before. This comp and these layers are using a number of effects plug-ins, possibly more than I’ve used before (that’s one reason I was precomposing some layers)
    Anyone have any idea what’s going on here?
    Makine replied 19 years, 11 months ago 4 Members · 3 Replies
  • -=Herb=- Create COW Profile Image
    -=herb=-
    September 25, 2006 at 5:57 pm
    Just a few thoughts. Its a slower but more reliable way of working. Try rendering your movie to a tga sequence then re-importing that sequence if it renders and rendering your quicktime movie. Since you will be rendering frame by frame you will know exactly what frame crashes, and be able to narrow down what plugin conflicts you may be having. This usually crops up with cracked plugs, just a note if your using a ‘demo’ 😉
  • Bill Mcq
    September 26, 2006 at 8:41 pm
    Just wanted to update the “Render On Crash” post I made.
    It appears now that an expression I had been using was the culprit.
    I’ve rewritten the expression and everything seems to be working fine with no crashes on renders thus far.
    I want to thank Herb for his suggestion on tracing down the culprit. I also want to direct anyone who seems to have rendering and memory issues to the archives. Search “Secret” and follow the directions.
    Bill
  • Makine
    September 28, 2006 at 9:50 pm
    Hi Bill
    I tried to search “secret” and I could find the fix?
    Can you point out where it is?
    Thansk a lot for your kind help
    MAkinE studios
    1733 Abbot Kinney Blvd. Ste D
    Venice, CA 90291
    PH 310-8212070
