Activity Forums Apple Final Cut Pro crashing every time i use a Core Melt plugin
  • crashing every time i use a Core Melt plugin
    Posted by Julian Bowman on December 22, 2012 at 12:25 am
    i have the core melt complete V2 suite of plugins. They are loaded in the transitions folder but every time i touch one it crashes fcpx. Have tried a dissolve from another folder of transitions and that works fine.
    anyone else had/having issue with the core melt filters? this one is actually a deal breaker on fcpx as i use a couple as part of ongoing work with a couple of clients and is one of the reasons i shied away from CS6 in the end because core melt couldn’t make them work properly there.
    Have tried 4 times now and each time i click and hold to drag it across it kills fcpx.
    Julian Bowman replied 13 years, 8 months ago 2 Members · 2 Replies
  • Charlie Austin
    December 22, 2012 at 8:06 am
    [Julian Bowman] “anyone else had/having issue with the core melt filters? this one is actually a deal breaker on fcpx as i use a couple as part of ongoing work with a couple of clients and is one of the reasons i shied away from CS6 in the end because core melt couldn’t make them work properly there.”
    Are you running 10.0.7? If so, you need to reinstall the updated version from their website. That should fix it. 🙂
    ~”It is a poor craftsman who blames his tools.”~
  • Julian Bowman
    December 22, 2012 at 8:28 am
    Excellent, many thanks Charlie will get their update as my plugins are older than fcpx.
    Thank you.
