Activity Forums Adobe Premiere Pro Crashing and more CUDA issues?
  • Crashing and more CUDA issues?
    Posted by Harry Pallenberg on June 6, 2015 at 10:14 pm
    So Premiere CC (newest version) has been locking up and a general pain the ass. I have to quit and it all goes away, but then I have to force quit as it stays open in the background. Does that at least once every few hours. So I had Adobe tech take over my computer and they updated the CUDA drivers and then it got WORSE… like I got the grey screen saying the computer must restart.
    So obviously I had the guy remove the cuda driver… Seems like it locks up about as much as before but
    exporting now take 2-3 times as long as before? Is that maybe because he put it to software vs. GPU under the Project Settings? Also if I wanted to try updating the Cuda drivers again maybe I get a different version?
    He installed 7.0.36 (which the CUDA page says this about:
    Supports all NVIDIA products available on Mac HW.
    Note: this driver does not support the older generation GPUs with SM1.x. Please download CUDA driver 6.5.45 which supports SM1.x.
    Maybe I should try 6.5.45 which says this:
    Note: this driver does not support GeForce GTX980 and GTX970. Please download the equivalent CUDA driver 6.5.46 which supports GeForce GTX980 and GTX970
    This is the card I actually have: NVIDIA GeForce GTX 775M 2048 MB graphics
    iMac 3.4 i5 running 10.9.5
    Any ideas at all? I did the thing where I fixed the read/write permission on all the Adobe sub folders?
    Any other things I can try?
    Harry
    Forum Cowmunity Leader: Indie & Doc
    Current: I’m Not Leaving https://vimeo.com/118508646
    Previous: http://www.WhereTheyRaced.com
    Web: http://www.SunnyAndMildMedia.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Andrew Kimery replied 11 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    June 7, 2015 at 12:55 am
    Hey Harry! Long time no see…
    Call me tomorrow or Monday, I can either help you to fix it, or I can direct you toward a fix.
    If you no longer have my number check my website… @ drwfilms dot com.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Andrew Kimery
    June 7, 2015 at 6:23 pm
    [Harry Pallenberg] “Any ideas at all? I did the thing where I fixed the read/write permission on all the Adobe sub folders?
    Any other things I can try?”
    Switch to OpenCL for GPU acceleration (and you have to do a few manual steps to completely uninstall the CUDA driver which might be the info DRW can give you). There is an ongoing problem using CUDA that, last I heard, seemed to an issue that Nvidia needs to address.
  • David Roth weiss
    June 7, 2015 at 6:29 pm
    Harry is still on Mavericks, so in theory he should not be having the Cuda issues most here are reporting under Yosemite. Some have reported having the same issues under Mavericks, but I’m not, nor are any of my friends and clients who have proper clean installs of the OS and the proper Nvidia and Cuda drivers.
    David Roth Weiss
  • Andrew Kimery
    June 7, 2015 at 7:21 pm
    Put me in the Mavericks column. I’m on Mavericks w/CUDA 6.5.46 and have to run OpenCL. When I was on Mountain Lion w/the same version of PPro and CUDA I didn’t have any problems.
  • David Roth weiss
    June 7, 2015 at 7:46 pm
    Well, you too should call me tomorrow Andrew… We can compare notes on our systems to determine what’s different and why yours isn’t up to snuff.
    David Roth Weiss
  • Harry Pallenberg
    June 7, 2015 at 8:11 pm
    Yes David… long time.
    I’ll call as well… maybe after you 2 talk and compare notes. THANKS!
    Harry
  • Andrew Kimery
    June 7, 2015 at 11:01 pm
    In the middle of a gig and all is going well with OpenCL and I don’t want to gum up the works. When I wrap this project though I’ll give you a call, David.
