Activity Forums Boris FX Particle Illusion Crashes with librairies management.
  • Crashes with librairies management.
    Posted by Vincent Vacher on April 15, 2006 at 12:46 pm
    Hello to all,
    i’m new with PI i bought just today after tried the demo. Here is my problem : Sometimes in librairies management PI crashes with a windows message error wich close the PI application.
    Is it a known problem? is there something special to do ?
    Thanks in advance for help.
    VINCENT
    Vincent Vacher replied 20 years, 5 months ago 2 Members · 3 Replies
  • Elvis Deane
    April 16, 2006 at 4:31 am
    It’s not a problem that I know of, and I’ve used the manager quite a bit. Is it when you do a specific task in the manager, or does it just happen at random times?
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
  • Vincent Vacher
    April 16, 2006 at 12:41 pm
    Hello, I had repetitive error renaming the last folder after deleting all folder of the library to create a new empty library, i took a downloaded library, then i did the same thing but starting from default library and now i have no problem.
    thanks for your attention.
    VINCENT
  • Vincent Vacher
    April 19, 2006 at 6:28 am
    Hi Elvis,
    I know why i have some crashes in library manager, it’s due to a reference to an old library folder (from the DEMO).
    Because demo uninstall program doesn’t remove PI root folder when i have installed full version it keeps reference to demo folder, and because i have deleted manualy demo folder that produces crashes because the folder doesn’t exist.
    I solved my problem removing a key in register (library path).
    VINCENT
