Crashes when rendering
Posted by Paul Gilmore on May 7, 2012 at 3:15 amI guess I can’t render footage with Vegas Pro 11? I’ve been trying all day to render a project and everytime Vegas 11 crashes!
Any suggestions?
“Film is a dramatized reality and it is the director’s job to make it appear real… an audience should not be conscious of technique.” – David Lean
Malcolm Matusky replied 14 years, 4 months ago 11 Members · 32 Replies -
Angelo Mike
May 7, 2012 at 3:27 amNo idea without more information. What are your project settings, render settings, and computer specs?
http://www.scenethroughglass.com
Paul Gilmore
May 7, 2012 at 3:38 ameverything is the way it should be.. Ive never ever had a problem using Vegas til I started using pro 11
setting: NTSC DV Widescreen (720×480, 29.970 fps)
Rendering: Mpg2 Widescreen
Win 7 64bit, 8GB Ram, 2TB HD, Nivida Gforce 550 video card, AMD 2.80GHz processor“Film is a dramatized reality and it is the director’s job to make it appear real… an audience should not be conscious of technique.” – David Lean
Angelo Mike
May 7, 2012 at 3:43 am -
Paul Gilmore
May 7, 2012 at 3:59 aman hour and whatever the default bitrate is. I dont think settings is the issue, I’ve used Vegas since pro 6 and the settings have never changed and always worked.. I think it might just be the software, I’ve had so many problems with pro 11
Angelo Mike
May 7, 2012 at 4:12 amThe only problems I’ve had with rendering to the DV Widescreen setting is when I tried to make the bit rate too low or high for a given project settings quality.
And since it is Vegas 11, the first thing I’d try is restarting the project/my computer and trying again. Or test rendering a small part of the video.
Paul Gilmore
May 7, 2012 at 4:14 amalready tried that more then once… didn’t solve the issue
Angelo Mike
May 7, 2012 at 4:22 am -
Paul Gilmore
May 7, 2012 at 4:32 amfilmed with an FX-7 I believe it’s AVI.. however this isn’t moving video, it’s a photo montage, bunch of photos put together with music
Steve Rhoden
May 7, 2012 at 8:39 amDo you have the same problem rendering anything else Paul?
Steve Rhoden
(Cow Leader)
Film Editor & Compositor.
Filmex Creative Media.
1-876-832-4956 -
Paul Gilmore
May 7, 2012 at 8:50 amYes. I completed a wedding through out the editing Vegas 11 would crash. After I finally manged through it snd tried to render it would crash half way through. Very odd
