Activity › Forums › Apple Motion › Crashes when I import Generator content
  • Crashes when I import Generator content
    Posted by Robert Phillips on December 4, 2010 at 3:07 pm
    Good morning
    I’m having some weird behavior happen whenever I import “Generator” content. Whenever I add content to the project, I get the spinning beach ball of doom.
    The error is posted below. Can anyone share insight on what’s going on? I would appreciate it greatly! I’m using Motion 4 on a Mac Pro OS 10.5.8
    2.8 GHz Quad Core Intel Xeon
    4 GB 800 MHz DDR2 FB-DIMM
    error message:
    Date/Time: 2010-12-04 08:57:28 -0500
    OS Version: 10.5.8 (Build 9L30)
    Architecture: i386
    Report Version: 4
    Command: Motion
    Path: /Applications/Motion.app/Contents/MacOS/Motion
    Version: 4.0.3 (729)
    Build Version: 62
    Project Name: Motion
    Source Version: 7290000
    Parent: launchd [141]
    PID: 15039
    Event: hang
    Time: 7.05s
    Steps: 46
    Process: Motion [15039]
    ADDRESS BINARY
    00001000 /Applications/Motion.app/Contents/MacOS/Motion
    00143000 /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
    0019c000 /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
    001b5000 /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
    002c4000 /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
    00588000 /Applications/Motion.app/Contents/MacOS/../Frameworks/AERegistration.framework/Versions/A/AERegistration
    005ab000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
    005ce000 /Applications/Motion.app/Contents/MacOS/../Frameworks/AEProfiling.framework/Versions/A/AEProfiling
    005df000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
    007b8000 /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    00895000 /Library/Frameworks/XSKey.framework/Versions/A/XSKey
    008c2000 /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
    008d3000 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    008d8000 /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
    00d83000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Versions/A/Ozone
    01b06000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
    01c8d000 /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
    01e98000 /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
    02005000 /System/Library/Frameworks/Python.framework/Versions/2.5/Python
    0211e000 /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    021a2000 /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    021d7000 /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
    021fb000 /usr/lib/libedit.2.dylib
    0221c000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
    02242000 /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    023ed000 /usr/lib/libexpat.1.dylib
    02459000 /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    06647000 /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    067fa000 /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
    07c24000 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    07c46000 /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
    07cd4000 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    07d50000 /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
    07d58000 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    07da4000 /Library/Frameworks/Motion.framework/Versions/A/Motion
    07dac000 /Library/QuickTime/macam.component/Contents/MacOS/macam
    07f23000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
    07fb1000 /Library/Plug-Ins/FxPlug/Lock & Load X.fxplug/Contents/MacOS/Lock & Load X
    07ff3000 /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
    07fff000 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    08017000 /usr/lib/libmx.A.dylib
    08026000 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    08035000 /Library/Plug-Ins/FxPlug/Lock & Load.fxplug/Contents/MacOS/Lock & Load
    08077000 /Library/Plug-Ins/FxPlug/VTwinFx.fxplug/Contents/MacOS/VTwinFx
    08200000 /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
    08436000 /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
    0862f000 /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/Versions/A/TextFramework
    08aa0000 /Library/Frameworks/PixlockCVL.framework/Versions/A/PixlockCVL
    08c3f000 /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
    09200000 /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
    0930c000 /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
    0975b000 /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
    097a2000 /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
    09879000 /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
    09899000 /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
    098be000 /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
    098dc000 /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
    098ef000 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    0996e000 /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
    0999e000 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    099aa000 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    09a1e000 /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
    09a66000 /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
    09b42000 /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
    09b56000 /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
    09b69000 /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/Resources/LeopardPanels.bundle/Contents/MacOS/LeopardPanels
    09ba8000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
    09bb2000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    09e1d000 /Applications/Motion.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
    0defa000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    0ec53000 /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    0ec69000 /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
    0f000000 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    0f400000 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    0f605000 /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
    10000000 /Applications/Motion.app/Contents/MacOS/../Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
    200f3000 /System/Library/PrivateFrameworks/Helium.framework/Versions/A/Helium
    20c42000 /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
    2140d000 /Applications/Motion.app/Contents/PlugIns/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
    21419000 /System/Library/PrivateFrameworks/Helium.framework/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
    21800000 /Applications/Motion.app/Contents/PlugIns/FxPlug/Filters.bundle/Contents/MacOS/Filters
    ba900000 /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
    Thread id: f239790
    User stack:
    46 ??? [0x2746]
    46 ??? [0x55de]
    46 _NSProApplicationMain + 325 (in ProKit) [0x2e714c]
    46 -[NSApplication run] + 867 (in AppKit) [0x95207fe7]
    46 ??? [0x839b]
    46 -[NSApplication sendEvent:] + 2939 (in AppKit) [0x952aa6a5]
    46 -[OZDocumentWindow sendEvent:] + 90 (in Ozone) [0x105e9ea]
    46 -[NSProWindow sendEvent:] + 273 (in ProKit) [0x309009]
    46 -[NSWindow sendEvent:] + 5381 (in AppKit) [0x952ddaf7]
    46 -[NSControl mouseDown:] + 888 (in AppKit) [0x952df3b8]
    46 -[NSProButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 288 (in ProKit) [0x3218b5]
    46 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 541 (in AppKit) [0x952dfafe]
    46 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1827 (in AppKit) [0x952e02ab]
    46 -[NSCell _sendActionFrom:] + 169 (in AppKit) [0x952e0c52]
    46 -[NSControl sendAction:to:] + 108 (in AppKit) [0x952e0dcc]
    46 -[NSProApplication sendAction:to:from:] + 124 (in ProKit) [0x2e64cb]
    46 -[NSApplication sendAction:to:from:] + 112 (in AppKit) [0x952e0e8f]
    46 -[OZCanvasView pause:] + 46 (in Ozone) [0x131f05e]
    46 -[OZGLViewer doPause] + 695 (in Ozone) [0xdcd397]
    46 __ZN15OZRenderManager5abortEbj + 195 (in Ozone) [0xf0f983]
    46 __ZN21OZRendererBuilderUnit5abortEb + 24 (in Ozone) [0x13c29e8]
    46 __ZN15OZExecutionUnit9abortWaitEv + 124 (in Ozone) [0x108cb0c]
    46 __ZN11PCSemaphore4waitEv + 45 (in ProCore) [0x7dfebf]
    46 ___semwait_signal + 10 (in libSystem.B.dylib) [0x90dd344e]
    Kernel stack:
    1 _i386_astintr + 47 [0x1aa272]
    1 _ast_taken + 247 [0x129472]
    1 _bsd_ast + 721 [0x384ced]
    1 _postsig + 351 [0x383274]
    1 _exit1 + 392 [0x377b31]
    1 _task_terminate_internal + 313 [0x13bb81]
    1 _vm_map_remove + 145 [0x16b18d]
    1 _vm_map_simplify + 4131 [0x16abc5]
    1 _pmap_remove_range + 612 [0x194f39]
    Thread id: c7d54f0
    User stack:
    45 _thread_start + 34 (in libSystem.B.dylib) [0x90dfd012]
    45 __pthread_start + 321 (in libSystem.B.dylib) [0x90dfd155]
    45 __Z11CMMConvTaskPv + 54 (in ColorSync) [0x97787d4e]
    45 __Z20pthreadSemaphoreWaitP18t_pthreadSemaphore + 42 (in ColorSync) [0x977753f8]
    45 ___semwait_signal + 10 (in libSystem.B.dylib) [0x90dd344e]
    Thread id: d3f78b8
    User stack:
    Thread id: d3f74f0
    User stack:
    Thread id: cdcd4f0
    User stack:
    45 _glvmDoWork + 162 (in libGLProgrammability.dylib) [0x91729b32]
    Thread id: f23a6b0
    User stack:
    45 __ZN3AVS26DestroyAVCDeviceControllerEPNS_19AVCDeviceControllerE + 317 (in DVCPROHDMuxer) [0x990698f]
    45 _CFRunLoopRun + 84 (in CoreFoundation) [0x95f5bb04]
    45 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x90dcc266]
    Thread id: c5c4000
    User stack:
    45 __ZN9CAPThread5EntryEPS_ + 96 (in CoreAudio) [0x93dc1480]
    45 __ZN10HALRunLoop9OwnThreadEPv + 160 (in CoreAudio) [0x93dc15f8]
    45 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x95f5baa8]
    Thread id: d71fba0
    User stack:
    45 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x97100fbb]
    45 __ZN23TSystemNotificationTask26SystemNotificationTaskProcEPv + 123 (in DesktopServicesPriv) [0x96da4d0f]
    Thread id: eb6ca78
    User stack:
    45 __ZN25TFSEventsNotificationTask28FSEventsNotificationTaskProcEPv + 216 (in DesktopServicesPriv) [0x96da4e88]
    Thread id: f23dba0
    User stack:
    45 __ZN13TNodeSyncTask12SyncTaskProcEPv + 84 (in DesktopServicesPriv) [0x96dafe6a]
    45 _MPWaitOnQueue + 208 (in CarbonCore) [0x97102a60]
    45 _TSWaitOnConditionTimedRelative + 202 (in CarbonCore) [0x970e1c36]
    45 _TSWaitOnCondition + 126 (in CarbonCore) [0x97102de3]
    Thread id: 7c59f20
    User stack:
    45 ___select + 10 (in libSystem.B.dylib) [0x90e1b6fa]
    Thread id: c7d2790
    User stack:
    45 _ReadSchedulerThreadEntryPoint + 4728 (in QuickTimeComponents) [0x91daedf6]
    45 _TSWaitOnSemaphoreCommon + 422 (in CarbonCore) [0x970e1a42]
    45 _TSWaitOnConditionTimedRelative + 246 (in CarbonCore) [0x970e1c62]
    45 _semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x90dcc2c6]
    Thread id: d3f52e8
    User stack:
    45 _QTSurfaceRendererScheduledDisplayThread + 158 (in QTKit) [0x91ca3e52]
    Thread id: d3f87d8
    User stack:
    45 _QTVisualContextImageProviderWorkLoop + 122 (in QTKit) [0x91c9d70a]
    Thread id: eb6f048
    User stack:
    45 _IcpDecompressorComponentDispatch + 1771 (in AppleProResCodec) [0x8c4940b]
    45 _semaphore_wait_signal_trap + 10 (in libSystem.B.dylib) [0x90dcc2ae]
    Thread id: 8c02000
    User stack:
    Thread id: 7c5c8b8
    User stack:
    Thread id: d3f5e40
    User stack:
    Thread id: d71ce40
    User stack:
    45 ___NSThread__main__ + 308 (in Foundation) [0x913329a4]
    45 -[NSThread main] + 45 (in Foundation) [0x91332dfd]
    45 -[NSUIHeartBeat _heartBeatThread:] + 753 (in AppKit) [0x952756e8]
    45 -[NSConditionLock lockWhenCondition:] + 69 (in Foundation) [0x91378b35]
    45 -[NSConditionLock lockWhenCondition:beforeDate:] + 144 (in Foundation) [0x91378bd0]
    45 -[NSCondition waitUntilDate:] + 236 (in Foundation) [0x91378dbc]
    Thread id: cdce048
    User stack:
    45 __ZN8PCThread7startupEPv + 18 (in ProCore) [0x7e00a8]
    45 __ZN15OZExecutionUnit18executeLoopWrapperEPv + 94 (in Ozone) [0x108cede]
    45 __ZN15OZExecutionUnit11executeLoopEv + 75 (in Ozone) [0x108cddb]
    Thread id: cdcd128
    User stack:
    45 __ZN15OZExecutionUnit11executeLoopEv + 197 (in Ozone) [0x108ce55]
    45 __ZN12OZRenderUnit7executeEv + 188 (in Ozone) [0x108f66c]
    45 __ZN12OZRenderUnit24processRenderInstructionEP19OZRenderInstruction + 2312 (in Ozone) [0x108ed58]
    45 __ZN10GLRenderer6renderEP7OZSceneR14OZRenderParams + 4132 (in Ozone) [0x10557d4]
    45 __ZN10GLRenderer27findOrCreateRendererBuilderEP7OZSceneR14OZRenderParamsb + 780 (in Ozone) [0x10527bc]
    45 __ZN11PCSemaphore4waitEv + 45 (in ProCore) [0x7dfebf]
    Thread id: d3f5a78
    User stack:
    Thread id: d3f4000
    User stack:
    Thread id: d3f6208
    User stack:
    45 __ZN21OZRendererBuilderUnit7executeEv + 25 (in Ozone) [0x13c3969]
    45 __ZN21OZRendererBuilderUnit24processRenderInstructionEP28OZRendererBuilderInstruction + 1412 (in Ozone) [0x13c3434]
    45 __ZN10GLRenderer12getFrameNodeEP7OZSceneR14OZRenderParamsP10HGRendererPl + 164 (in Ozone) [0x10515c4]
    45 __ZN10GLRenderer27getFrameNodeIncludingFieldsEP7OZSceneR14OZRenderParamsP10HGRendererPl + 999 (in Ozone) [0x1050c47]
    45 __ZN10GLRenderer25getFrameNodeForSingleTimeEP7OZSceneR14OZRenderParamsP10HGRendererddPl + 940 (in Ozone) [0x105002c]
    45 __ZN10GLRenderer25getSceneHeNodeFromLiWorldEP7OZSceneRK15OZSceneSettingsR14OZRenderParams5PCPtrI7LiGroupEP10HGRendereriiddPl + 2312 (in Ozone) [0x104a428]
    45 __ZN7LiAgent9getHeliumEP13LiImageSource + 4789 (in Lithium) [0x1d79895]
    45 __ZN10LiRenderer9getHeliumER7LiAgent + 51 (in Lithium) [0x1d106e3]
    45 __ZN16LiRenderInstance9getHeliumER7LiAgent + 294 (in Lithium) [0x1db4d36]
    45 __ZN16LiRenderInstance16buildHeliumGraphER7LiAgent + 524 (in Lithium) [0x1db2abc]
    45 __ZN16LiRenderInstance7collectEv + 2129 (in Lithium) [0x1db24f1]
    45 __ZN16LiRenderInstance9collect3DEP13LiSceneObjectR14LiCollectState + 1580 (in Lithium) [0x1db070c]
    45 __ZN16LiRenderInstance12collectGroupEP7LiGroupR14LiCollectStateS3_ + 427 (in Lithium) [0x1db0a9b]
    45 __ZN16LiRenderInstance9collect3DEP13LiSceneObjectR14LiCollectState + 1385 (in Lithium) [0x1db0649]
    45 __ZN16LiRenderInstance12collectGeodeEP7LiGeodeR14LiCollectState + 913 (in Lithium) [0x1daf841]
    45 __ZN17LiPolygonInstance8makeNodeERK9LiClipSet + 1713 (in Lithium) [0x1d89c61]
    45 __ZN15OZLiFxGenerator9getHeliumER7LiAgent + 133 (in Ozone) [0x1374ee5]
    45 __ZN18OZProPlugGenerator9getHeliumER7LiAgentfR14OZRenderParams + 1947 (in Ozone) [0x11880db]
    45 __Z24OZProPlug_CallFrameSetupPvP11objc_object12FxRenderInfoP11FxImageInfoPaS5_ + 122 (in Ozone) [0x136e03a]
    45 __Z17LockRecursiveLockPv + 34 (in Ozone) [0x13a9a92]
    Thread id: cdcaf20
    User stack:
    Thread id: d3f7c80
    User stack:
    Thread id: c5c6208
    User stack:
    Thread id: cdcb2e8
    User stack:
    Thread id: c7d3a78
    User stack:
    45 _jpegdecompress_MPLoop + 79 (in QuickTimeComponents) [0x9249d4cb]
    Thread id: f239b58
    User stack:
    Thread id: eb6b000
    User stack:
    Thread id: cdca3c8
    User stack:
    Thread id: c5c4b58
    User stack:
    45 __ZN12OZRenderUnit24processRenderInstructionEP19OZRenderInstruction + 167 (in Ozone) [0x108e4f7]
    45 __ZN10GLRenderer36renderSingleDocumentObjectWithHeliumEP12OZRenderNodeR14OZRenderParams + 474 (in Ozone) [0x105737a]
    45 __ZN10GLRenderer27findOrCreateRendererBuilderEP12OZRenderNodeR14OZRenderParamsb + 930 (in Ozone) [0x1051b62]
    Thread id: f5b8410
    User stack:
    Thread id: cdcc208
    User stack:
    Thread id: cdcb6b0
    User stack:
    45 __ZN21OZRendererBuilderUnit24processRenderInstructionEP28OZRendererBuilderInstruction + 1571 (in Ozone) [0x13c34d3]
    45 __ZN10GLRenderer12getFrameNodeEP12OZRenderNodeR14OZRenderParamsP10HGRendererPl + 2678 (in Ozone) [0x104ba06]
    45 __ZN16LiRenderInstance12collectGroupEP7LiGroupR14LiCollectStateS3_ + 2549 (in Lithium) [0x1db12e5]
    45 __ZN18OZProPlugGenerator9getHeliumER7LiAgentfR14OZRenderParams + 3164 (in Ozone) [0x118859c]
    45 __Z20OZProPlug_CallRenderPvP11objc_objectPK16OZProcessControlP7FxImageS6_12FxRenderInfoRK14OZRenderParams + 737 (in Ozone) [0x136e561]
    40 -[GeneratorDefaultBase renderOutput:withInfo:] + 154 (in Filters) [0x218d513c]
    12 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 9883 (in Filters) [0x21873497]
    12 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
    12 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
    2 _gleRunVertexSubmitImmediate + 977 (in GLEngine) [0x671e9b1]
    2 _gleRunVertexSubmitImmediate + 6176 (in GLEngine) [0x671fe00]
    1 _gleGetOffsetForCode + 0 (in GLEngine) [0x6718410]
    1 _gleRunVertexSubmitImmediate + 6170 (in GLEngine) [0x671fdfa]
    1 _gleRunVertexSubmitImmediate + 6164 (in GLEngine) [0x671fdf4]
    1 _gleRunVertexSubmitImmediate + 1358 (in GLEngine) [0x671eb2e]
    1 _gleRunVertexSubmitImmediate + 430 (in GLEngine) [0x671e78e]
    1 _gleRunVertexSubmitImmediate + 958 (in GLEngine) [0x671e99e]
    1 _gleRunVertexSubmitImmediate + 3941 (in GLEngine) [0x671f545]
    1 _gleRunVertexSubmitImmediate + 3870 (in GLEngine) [0x671f4fe]
    6 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 9143 (in Filters) [0x218731b3]
    6 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
    6 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
    1 _gleRunVertexSubmitImmediate + 984 (in GLEngine) [0x671e9b8]
    1 _gleRunVertexSubmitImmediate + 35 (in GLEngine) [0x671e603]
    1 _gleRunVertexSubmitImmediate + 6182 (in GLEngine) [0x671fe06]
    1 _gleRunVertexSubmitImmediate + 500 (in GLEngine) [0x671e7d4]
    1 _gleLLVMSubmitFunc + 102 (in GLEngine) [0x671c436]
    1 _gleCalculateDropEdge + 26 (in GLEngine) [0x671829a]
    5 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 7711 (in Filters) [0x21872c1b]
    5 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
    5 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
    1 _gleRunVertexSubmitImmediate + 3864 (in GLEngine) [0x671f4f8]
    1 _gleCalculateDropEdge + 48 (in GLEngine) [0x67182b0]
    1 __Z19calculateCellValuesiiifP11SCellValues + 2014 (in Filters) [0x21870c56]
    1 __Z19calculateCellValuesiiifP11SCellValues + 86 (in Filters) [0x218704ce]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1742 (in Filters) [0x21870b46]
    1 __Z19calculateCellValuesiiifP11SCellValues + 98 (in Filters) [0x218704da]
    1 __Z19calculateCellValuesiiifP11SCellValues + 174 (in Filters) [0x21870526]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1962 (in Filters) [0x21870c22]
    1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 8403 (in Filters) [0x21872ecf]
    1 _glVertex2f + 38 (in libGL.dylib) [0x96c4b4a6]
    1 _glVertex2f_Exec + 72 (in GLEngine) [0x668d728]
    1 _gleRunVertexSubmitImmediate + 6032 (in GLEngine) [0x671fd70]
    1 __Z19calculateCellValuesiiifP11SCellValues + 2259 (in Filters) [0x21870d4b]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1957 (in Filters) [0x21870c1d]
    1 _glVertex2f_Exec + 73 (in GLEngine) [0x668d729]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1847 (in Filters) [0x21870baf]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1979 (in Filters) [0x21870c33]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1528 (in Filters) [0x21870a70]
    1 __Z19calculateCellValuesiiifP11SCellValues + 799 (in Filters) [0x21870797]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1764 (in Filters) [0x21870b5c]
    1 _glMultiTexCoord4f + 13 (in libGL.dylib) [0x96c4fd9d]
    1 __Z19calculateCellValuesiiifP11SCellValues + 1161 (in Filters) [0x21870901]
    1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 7115 (in Filters) [0x218729c7]
    1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 6911 (in Filters) [0x218728fb]
    1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 6311 (in Filters) [0x218726a3]
    1 -[PerlinNoiseV2 canThrowRenderOutput:withInfo:] + 9731 (in Filters) [0x218733ff]
    1 ??? [0x2193b032]
    Kernel stack:
    45 _PE_incoming_interrupt + 131 [0x44e416]
    45 _lapic_interrupt + 121 [0x1b16c0]
    45 _sync_iss_to_iks + 114 [0x1aa3ae]
    Thread id: f5b8048
    User stack:
    44 _thread_start + 34 (in libSystem.B.dylib) [0x90dfd012]
    44 __pthread_start + 321 (in libSystem.B.dylib) [0x90dfd155]
    44 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x97100fbb]
    44 __ZN15TFolderSizeTask18FolderSizeTaskProcEPv + 104 (in DesktopServicesPriv) [0x96db1db4]
    44 _MPWaitOnQueue + 208 (in CarbonCore) [0x97102a60]
    44 _TSWaitOnConditionTimedRelative + 246 (in CarbonCore) [0x970e1c62]
    44 _semaphore_timedwait_signal_trap + 10 (in libSystem.B.dylib) [0x90dcc2c6]
    Process: ATSServer [157]
    Path: /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/ATSServer
    ADDRESS BINARY
    00001000 /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/ATSServer
    Thread id: 768da78
    User stack:
    46 ??? [0x4b46]
    46 ??? [0xdd21f]
    46 _CFRunLoopRun + 84 (in CoreFoundation) [0x95f5bb04]
    1 _CFRunLoopRunSpecific + 3896 (in CoreFoundation) [0x95f5b6b8]
    1 ___CFMachPortPerform + 117 (in CoreFoundation) [0x95f36ff5]
    1 ??? [0xda8a9]
    1 ??? [0xd7dde]
    1 ??? [0xe4018]
    1 ??? [0xa97c6]
    1 ??? [0xa946e]
    1 ??? [0xa8001]
    1 ??? [0xa7df5]
    1 ??? [0xa7bba]
    1 ??? [0xafb9d]
    1 ??? [0xab835]
    1 ??? [0xa61cf]
    1 _sqlite3_step + 29 (in libsqlite3.0.dylib) [0x96f7855d]
    1 _sqlite3Step + 386 (in libsqlite3.0.dylib) [0x96f77ea2]
    1 _sqlite3VdbeExec + 22966 (in libsqlite3.0.dylib) [0x96f71656]
    1 _sqlite3VdbeHalt + 3198 (in libsqlite3.0.dylib) [0x96f2746e]
    1 _fsync$UNIX2003 + 10 (in libSystem.B.dylib) [0x90e10d3e]
    Kernel stack:
    1 _unix_syscall + 572 [0x3e3a7f]
    1 _fsync_nocancel + 102 [0x1e7f15]
    1 _VNOP_FSYNC + 104 [0x1f51fe]
    1 _GetLogicalBlockSize + 42477 [0x348441]
    1 _GetLogicalBlockSize + 25373 [0x344171]
    1 _cluster_push + 40 [0x1d278f]
    1 _cluster_push_ext + 281 [0x1d2756]
    1 _vnode_waitforwrites + 167 [0x1dd32e]
    1 _msleep + 157 [0x3863e8]
    1 _uiomove + 653 [0x386037]
    1 _lck_mtx_sleep + 87 [0x130d90]
    1 _thread_block + 33 [0x136f20]
    1 _thread_block_reason + 135 [0x136e7c]
    1 _thread_setrun + 3597 [0x136217]
    1 _machine_idle + 271 [0x1ac3ec]
    Thread id: 7c5b208
    User stack:
    46 _mach_msg_trap + 10 (in libSystem.B.dylib) [0x90dcc266]
    Process: AirPort Base Station Agent [147]
    Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
    ADDRESS BINARY
    00001000 /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
    000f9000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
    0041c000 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    00424000 /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    004a8000 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    00524000 /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
    0052c000 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    00578000 /Library/Frameworks/Motion.framework/Versions/A/Motion
    00580000 /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    0065d000 /Library/QuickTime/macam.component/Contents/MacOS/macam
    Thread id: 76cd8b8
    User stack:
    46 ??? [0x25ad]
    46 ??? [0x2680]
    46 _NSApplicationMain + 574 (in AppKit) [0x951d51d8]
    46 -[NSApplication run] + 795 (in AppKit) [0x95207f9f]
    46 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (in AppKit) [0x9520ef88]
    46 __DPSNextEvent + 657 (in AppKit) [0x9520f6d5]
    46 _BlockUntilNextEventMatchingListInMode + 106 (in HIToolbox) [0x93823f39]
    46 _ReceiveNextEventCommon + 374 (in HIToolbox) [0x938240c5]
    46 _RunCurrentEventLoopInMode + 283 (in HIToolbox) [0x938242ac]
    46 _CFRunLoopRunInMode + 88 (in CoreFoundation) [0x95f5baa8]
    Thread id: 861a7d8
    User stack:
    46 ___select + 10 (in libSystem.B.dylib) [0x90e1b6fa]
    Process: AppleSpell [191]
    Path: /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
    ADDRESS BINARY
    00001000 /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
    000f9000 /usr/lib/liblangid.dylib
    Thread id: c5c7c80
    User stack:
    46 ??? [0x1e86]
    46 ??? [0x218d]
    46 -[NSSpellServer run] + 198 (in Foundation) [0x913aa596]
    Process: DashboardClient [218]
    Path: /System/Library/CoreServices/Dock.app/Contents/Resources/DashboardClient.app/Contents/MacOS/DashboardClient
    ADDRESS BINARY
    00001000 /System/Library/CoreServices/Dock.app/Contents/Resources/DashboardClient.app/Contents/MacOS/DashboardClient
    0002d000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
    000b5000 /Library/Widgets/iCal.wdgt/Calendar.widgetplugin/Contents/MacOS/Calendar
    000bf000 /Library/Widgets/Translation.wdgt/Translation.widgetplugin/Contents/MacOS/Translation
    000d8000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
    000df000 /Library/Widgets/World Clock.wdgt/WorldClock.widgetplugin/Contents/MacOS/WorldClock
    007d2000 /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaPluginCocoa.bundle/Contents/MacOS/JavaPluginCocoa
    007d9000 /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
    14e6f000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    15c45000 /Library/Widgets/Flight Tracker.wdgt/FlightTrackerComboBoxPlugin.plugin/Contents/MacOS/FlightTrackerComboBoxPlugin
    16920000 /System/Library/PrivateFrameworks/Calculate.framework/Calculate
    Thread id: c7d6ba0
    User stack:
    46 ??? [0x2b7a]
    46 ??? [0xa545]
    Thread id: cdccd60
    User stack:
    Thread id: cdcba78
    User stack:
    46 _thread_start + 34 (in libSystem.B.dylib) [0x90dfd012]
    46 __pthread_start + 321 (in libSystem.B.dylib) [0x90dfd155]
    46 __Z22CFURLCacheWorkerThreadPv + 388 (in CFNetwork) [0x9480818c]
    Thread id: c7d58b8
    User stack:
    Thread id: 78b0790
    User stack:
    Process: DashboardClient [219]
    ADDRESS BINARY
    000bc000 /Users/Ty PPC/Library/Widgets/Mamp Control.wdgt/mampwidget.widgetplugin/Contents/MacOS/mampwidget
    12eef000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    Thread id: cdcc5d0
    User stack:
    46 ??? [0x2b7a]
    46 ??? [0xa545]
    Thread id: c7d32e8
    User stack:
    Thread id: c7d4998
    User stack:
    Thread id: c5c4790
    User stack:
    Thread id: c5c5e40
    User stack:
    Process: DirectoryService [11]
    Path: /usr/sbin/DirectoryService
    ADDRESS BINARY
    00001000 /usr/sbin/DirectoryService
    00160000 /System/Library/PrivateFrameworks/DirectoryServiceCore.framework/Versions/A/DirectoryServiceCore
    Thread id: 6e6a048
    User stack:
    46 start + 54 (in DirectoryService) [0x1631a]
    46 _main + 2767 (in DirectoryService) [0x16e07]
    Thread id: 6d8cc80
    User stack:
    46 __ZN9DSLThread11_RunWrapperEPv + 84 (in DirectoryServiceCore) [0x168166]
    46 __ZN9DSCThread3RunEv + 39 (in DirectoryServiceCore) [0x167f5b]
    46 __ZN20CPluginRunLoopThread10ThreadMainEv + 222 (in DirectoryService) [0x22fc4]
    Thread id: 6d8aa78
    User stack:
    46 __ZN17CMigHandlerThread10ThreadMainEv + 303 (in DirectoryService) [0x231fd]
    Kernel stack:
    46 _dtrace_get_cpu_int_stack_top + 543 [0x198fa3]
    46 _mach_msg_overwrite_trap + 3808 [0x1270ea]
    46 _ipc_mqueue_receive + 750 [0x121292]
    46 _thread_block + 33 [0x136f20]
    46 _thread_continue + 1180 [0x136cb3]
    Thread id: 6e71e40
    User stack:
    46 _kevent + 10 (in libSystem.B.dylib) [0x90dfc9c6]
    Thread id: d3f4790
    User stack:
    46 ___syscall + 5 (in libSystem.B.dylib) [0x90e0e3a5]
    Thread id: f239000
    User stack:
    46 __ZN17CMigHandlerThread10ThreadMainEv + 162 (in DirectoryService) [0x23170]
    Process: Dock [160]
    Path: /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
    ADDRESS BINARY
    00001000 /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
    00400000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    Thread id: 7c5b998
    User stack:
    46 ??? [0x537a]
    46 ??? [0x97e97]
    46 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 213 (in Foundation) [0x913673d5]
    Thread id: 814e208
    User stack:
    46 ??? [0x1340d]
    Thread id: 8619c80
    User stack:
    Process: Finder [163]
    Path: /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
    ADDRESS BINARY
    00001000 /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
    004e5000 /System/Library/Frameworks/Collaboration.framework/Versions/A/Collaboration
    004fe000 /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    00527000 /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
    00596000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
    15b5a000 /System/Library/PrivateFrameworks/URLMount.framework/URLMount
    1662d000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    Thread id: 814e5d0
    User stack:
    46 ??? [0x9376]
    46 ??? [0xf3275]
    46 ??? [0x233b9]
    46 _RunApplicationEventLoop + 207 (in HIToolbox) [0x938812b3]
    46 __AcquireNextEvent + 58 (in HIToolbox) [0x93882b56]
    Thread id: 814cb58
    User stack:
    46 _PrivateMPEntryPoint + 56 (in CarbonCore) [0x97100fbb]
    46 __ZN23TSystemNotificationTask26SystemNotificationTaskProcEPv + 123 (in DesktopServicesPriv) [0x96da4d0f]
    Thread id: 814cf20
    User stack:
    46 __ZN25TFSEventsNotificationTask28FSEventsNotificationTaskProcEPv + 216 (in DesktopServicesPriv) [0x96da4e88]
    Thread id: 814c3c8
    User stack:
    46 __ZN13TNodeSyncTask12SyncTaskProcEPv + 84 (in DesktopServicesPriv) [0x96dafe6a]
    46 _MPWaitOnQueue + 208 (in CarbonCore) [0x97102a60]
    46 _TSWaitOnConditionTimedRelative + 202 (in CarbonCore) [0x970e1c36]
    46 _TSWaitOnCondition + 126 (in CarbonCore) [0x97102de3]
    Thread id: 86172e8
    User stack:
    Kernel stack:
    1 _kevent + 784 [0x37145b]
    1 _kevent_scan + 389 [0x371104]
    1 _thread_block_parameter + 32 [0x136efd]
    Thread id: 8616b58
    User stack:
    Thread id: f5b3410
    User stack:
    45 __ZN15TFolderSizeTask18FolderSizeTaskProcEPv + 104 (in DesktopServicesPriv) [0x96db1db4]
    Process: KernelEventAgent [35]
    Path: /usr/sbin/KernelEventAgent
    ADDRESS BINARY
    00001000 /usr/sbin/KernelEventAgent
    Thread id: 76ccd60
    User stack:
    Thread id: 777a5d0
    User stack:
    Process: Preview [698]
    Path: /Applications/Preview.app/Contents/MacOS/Preview
    ADDRESS BINARY
    00001000 /Applications/Preview.app/Contents/MacOS/Preview
    00201000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
    0046a000 /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    129c2000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    15672000 /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    15825000 /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
    181d4000 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
    Thread id: d71d5d0
    User stack:
    46 start + 54 (in Preview) [0x21b2]
    Thread id: d71f7d8
    User stack:
    Thread id: d71c2e8
    User stack:
    Thread id: d71bf20
    User stack:
    Thread id: d71bb58
    User stack:
    Thread id: d71b790
    User stack:
    Thread id: d71b3c8
    User stack:
    Thread id: d71b000
    User stack:
    Thread id: eb6fba0
    User stack:
    Thread id: eb6f7d8
    User stack:
    Thread id: eb6f410
    User stack:
    Process: QuickTime Player [12034]
    Path: /Applications/QuickTime Player.app/Contents/MacOS/QuickTime Player
    ADDRESS BINARY
    00001000 /Applications/QuickTime Player.app/Contents/MacOS/QuickTime Player
    0019e000 /Library/InputManagers/Cooliris/Cooliris.bundle/Contents/MacOS/Cooliris
    003e6000 /usr/lib/libmx.A.dylib
    00466000 /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
    0046e000 /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
    004f2000 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
    0056e000 /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
    00576000 /Library/QuickTime/Motion.component/Contents/MacOS/Motion
    005c2000 /Library/Frameworks/Motion.framework/Versions/A/Motion
    005ca000 /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
    0072a000 /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
    00775000 /Library/Frameworks/TSLicense.framework/Versions/A/TSLicense
    007b5000 /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
    007be000 /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
    12c58000 /Library/QuickTime/macam.component/Contents/MacOS/macam
    15981000 /Library/QuickTime/Flip4Mac WMV Import.component/Contents/MacOS/Flip4Mac WMV Import
    15ba8000 /System/Library/Components/AudioCodecs.component/Contents/MacOS/AudioCodecs
    15e43000 /Library/Audio/Plug-Ins/HAL/DVCPROHDAudio.plugin/Contents/MacOS/DVCPROHDAudio
    15eb7000 /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
    16178000 /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
    16300000 /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
    166d2000 /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
    16885000 /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
    18b3c000 /Library/QuickTime/Blackmagic Codec.component/Contents/MacOS/Blackmagic Codec
    18c48000 /Library/QuickTime/Flip4Mac WMV Advanced.component/Contents/MacOS/Flip4Mac WMV Advanced
    18e4d000 /Library/QuickTime/AppleAVCIntraCodec.comp
    Gareth Randall replied 15 years, 9 months ago 3 Members · 5 Replies
  • Zak Peric
    December 4, 2010 at 6:56 pm
    Delete the preferences of motion.
  • Robert Phillips
    December 4, 2010 at 7:27 pm
    Hi Zak
    Thanks I just tried that and still got the same spinning beach ball.
    Robert Phillips
    FCP 7
    Mac Pro OS 10.5.8
  • Gareth Randall
    December 4, 2010 at 10:25 pm
    Hi Robert,
    FWIW, trashing the preferences has NEVER solved any Motion problem I’ve ever had 🙂
    Have you confirmed that it’s a general problem, and not a project-specific one? In other words, if you create a new project, does the same thing happen when you try and import a generator? Individual projects can become corrupted for some reason, meaning that strange things start happening. You can often get around this by creating a new project and pasting in all the layers from the corrupted one.
    If it *is* a general problem, then your only real option is to reinstall Motion. Although Apple’s official line is that you have to reinstall the complete FCS suite, you don’t need to waste that much time. Just go and get the freeware FCS Remover, use it to completely uninstall *just* Motion, and then use the shareware app Pacifist to inspect the FCS install disc, locate the Motion installer package, and reinstall Motion on its own.
  • Robert Phillips
    December 5, 2010 at 7:37 pm
    Hi Gareth
    It was indeed a general issue- not project specific. I did the reinstall as you described and it seems to be working fine now. Thanks for the help!
    Robert Phillips
    FCP 7
    Mac Pro OS 10.5.8
  • Gareth Randall
    December 6, 2010 at 7:41 am
    Glad to help 🙂
