Activity Forums Adobe Premiere Pro crashed premiere
  • crashed premiere
    Posted by Paulo Oliveira on December 11, 2009 at 11:24 pm
    hello,
    My adobe premiere pro (CS3) crashed. I made some pictures with the Canon 5D Mark II and I get MPEG Streamclip to transcode the files into Premiere. Now it appears the error – adobe premiere.exe crashed – Premiere and reinstalled still the same! Anybody know what should I do?
    Paulo
    Paulo Oliveira replied 16 years, 8 months ago 2 Members · 2 Replies
  • Joseph Donnelly
    December 12, 2009 at 7:53 am
    I’d imagine it’s a codec issue.
    What’s your system specs and what the codec info on the clips/photos in question? I’ve had some serious issues with format compatibilities in the past.
    Also, why are you using Streamclip on photos? Premiere can import most photos and can also natively import .psds. Why not try either importing the photos unaltered or passing them through Photoshop and saving as .psd?
    Joseph Donnelly
    Editor
  • Paulo Oliveira
    December 12, 2009 at 12:18 pm
    Hello,
    I agree to be a codec issue, Since, Before installing the premiere Streamclip worked very well.
    Streamclip I installed because I am starting to work with the Canon 5d mark ii to record image, The images are excellent! The Premiere does not support the type of video file from Canon transcoding is necessary.
    What is strange is to reinstall premiere did not put back the premiere to work, Then I conclude it must be a codec own Windows???
    Paulo
