Activity › Forums › Boris FX Particle Illusion › Crash when rendering in avi format
  • Crash when rendering in avi format
    Posted by Bryan Steagall on November 4, 2007 at 1:42 am
    Alan:
    I’m having this issue consistently after upgrading to 3.0.2, when rendering to avi, the application stops and exits out.
    This is what I’ve tried so far: Unchecked and checked “don’t use texture ram for bg images”, I’ve also tried unchecking hardware acceleration. All give me the same result.
    I have no problems rendering to .jpg files (which is better anyway) but occasionally I do have a need to render in avi
    Any information you might need, let me know so I can get it to you..
    Bryan Steagall
    Bryan Steagall replied 18 years, 10 months ago 2 Members · 2 Replies
  • Alan Lorence
    November 5, 2007 at 11:08 am
    At what point does it crash? Do you get the codec-chooser dialog? If so, what codec are you choosing? (Try a different codec and see if it still crashes)
    And please email wondertouch support so I can add you to the 3.0.3 beta test.
    Alan.
    http://www.wondertouch.com
  • Bryan Steagall
    November 5, 2007 at 12:12 pm
    Alan,
    It crashes right after you select where to save the file and what format. If you choose avi or don’t choose anything (leaving it at “all supported formats”) , it hangs for a bit, then gives you:
    particleIllusion has encountered a problem and needs to close. We are sorry for the inconvenience.
    Only does this on avi (at least for me) I can still render in other formats..
    Thanks for the help!
    Bryan
