Activity Forums Media 100 crash using transitions
  • crash using transitions
    Posted by Chris Newlin on June 23, 2006 at 9:07 pm
    Getting fast and complete Media 100 “unexpectedly quit” crashes when I try to access any transition other than the dissolves. Either from the timeline or the “transitions” tab in the edit suite, when I try to put in DVE or wipe effect, BAM, it just shuts down.
    also have gotten some render crashes while rendering titles produced in AE in the title track.
    thoughts?
    bubba
    media 100 8.2.3a
    QT 7.1.1
    OS X 10.2.3
    Dual G4 1.42
    Chris Newlin replied 19 years, 10 months ago 2 Members · 2 Replies
  • Floh Peters
    June 23, 2006 at 10:10 pm
    Are you really running that on OSX 10.2.3? Then you probably have your reason for the problems. If not, have you installed a 3rd party transition ala BorisFX? Do you use the latest version of these effects?
  • Chris Newlin
    June 30, 2006 at 7:43 pm
    yeah, 10.2.3
    sorry, is that a bad?
    I had not had other probs until this showed up? I thought it was approved….
    er, what now.
    I can probably muddle by… I rarely use those transtions, however the render issue on the graphics track is a headache (when I lay down after effects produced graphics…)
    thoughts?
    cMn
