Activity Forums Apple Final Cut Pro Legacy crash report H.264 scalar
  • crash report H.264 scalar
    Posted by Tony Wise on January 27, 2009 at 7:25 pm
    I’m exporting using qt conversion an h.264 movie, while using the custom size of 480×270. I’ve done this hundreds of times in the past. Now, for some reason, it’s crashing fcp while giving me the error message that problem could be my h.264 scalar plugin. I haven’t installed any new plugins of late. I’ve dumped my prefs made sure qt was updated, still no luck. This only happens when I try to use a custom size on the export.
    any suggestions?
    thanks.
    Tony Wise replied 17 years, 7 months ago 3 Members · 4 Replies
  • Tom Chartrand
    January 29, 2009 at 3:56 am
    I’m with you on this one. The only difference between my system and a System I use that does not crash is the FX Factory plugin,
    Any insight from anyone?
    Tom
  • David Roth weiss
    January 29, 2009 at 4:45 am
    [Tom Chartrand] “The only difference between my system and a System I use that does not crash is the FX Factory plugin, “
    I won’t install FX Factory on my computer. It’s created instability on my system.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Tom Chartrand
    January 29, 2009 at 2:07 pm
    Hmmm, That’s strange. I can’t directly attribute the custom sizing crash issue to that, it’s just the only difference that I’ve noticed between two systems. However, I have had no stability issues with my FCP system otherwise.
  • Tony Wise
    January 29, 2009 at 4:07 pm
    I don’t have that plug-in set installed so it’s not that. I was thinking that perhaps it was the media. It’s a 1:30 sequence so I exported each shot seperately. Exported just fine. It’s only when I export the entire sequence that it crashes. Right now I’m doing a work around where I export out of FCP current setting and then take it into QT to export a scaled h264 movie.
