Activity Forums Avid Media Composer Crash record on a Panasonic HD1200A Deck!! (Please Help)
  • Crash record on a Panasonic HD1200A Deck!! (Please Help)
    Posted by Robert Combs on January 27, 2010 at 11:49 pm
    Ok, I’m trying to do a “Crash Record” on a Panasonic AJ-HD1200A Deck via firewire (because this is a software only version of Media Composer 4.0.5. on this Mac). I’ve been trying to lay off this 10 minute sequence for nearly 2 hours and I haven’t had any luck. What are the settings on the Digital Cut Tool supposed to be? I’m lost.
    I have deck control for the 1200A from the Digital cut tool. I’ve transcoded my entire spot to the DVCPRO HD format and Re-Created all of my title media. So, How do I do this “Crash Recored”? What are the settings? My only connection to the HD1200A is a Firewire cable. Is that ok for both Audio and Video?
    I’m stuck. Do I need to be using a blacked tape? Does there need to be a black burst signal feeding the BNC reference signal on the back of the deck for me to perform a digital “Crash Record” cut via Firewire.
    Can somebody please help? I’m rapidly running up against my deadline.
    Sincerely,
    Thank you. thank you. thank you. -Rob
    Jon Zanone replied 16 years, 7 months ago 2 Members · 5 Replies
  • Jon Zanone
    January 28, 2010 at 1:41 pm
    Is your timeline set to output 1394? I don’t remember exactly where, but there should be a little button somewhere saying ‘1394’… As long as that is set, you really shouldn’t need the digital cut tool – just hit play on your timeline and play / record on your deck…
    Jon
    Be curious, not judgmental.
    Walt Whitman
  • Robert Combs
    January 28, 2010 at 3:22 pm
    Thank you Jon. I’ve managed to get the spot onto tape at about 3am this morning.
    Now, my issue is a major digital artifacting. The audio sounds fine but the image while playing at regular speed, kinda resembles what you see when you are scanning a Digibeta tape in fast-forward.
    I think it probably has to do with a setting in the deck’s menu. I just can’t seem to figure out which one. Any guesses?
  • Jon Zanone
    January 31, 2010 at 3:36 am
    Is your deck set to HD?
    Jon
    Walt Whitman
  • Robert Combs
    January 31, 2010 at 5:58 pm
    definitely.
  • Jon Zanone
    February 1, 2010 at 2:23 am
    I’m pretty sure you can’t get HD through firewire. You’d need a Mojo DX to do that…
    Jon
    Walt Whitman
