Activity › Forums › Apple Final Cut Pro Legacy › Crash – Project Not Saved!?? UGH!
Posted by Blake Porter on January 23, 2015 at 8:25 pmFCP 7.0.3
Help.
FCP crashed. When the SAVED project is reopened, it’s NOT saved! Wow. This is very bad!
Anyway to find current project?Shane Ross replied 11 years, 8 months ago 2 Members · 5 Replies -
Shane Ross
January 23, 2015 at 8:53 pmLook in the AUTOSAVE VAULT. Not in there? The default location for that is in the DOCUMENTS folder, FINAL CUT PRO DOCUMENTS. But it might not always be there. Look in your FCP preferences to see if you have it set to another location.
There’s also a way to do this without knowing where it is. Open the project and in the FILE menu choose RESTORE PROJECT. It’ll then look in the autosave vault for the latest backup.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Blake Porter
January 23, 2015 at 9:04 pmShane, I always turn Autosave off… Looks like Restore Project looked for Auto Save. Thanks.
Shane Ross
January 23, 2015 at 9:56 pm[Blake Porter] ” I always turn Autosave off…”
Why? That’s your insurance policy! Well, now you see why you need to have it on.
Shane
Little Frog Post
Shane Ross
January 23, 2015 at 10:22 pmYes…Autosave is when the application will automatically save in an archive at regular intervals. So the entire project will be backed up in the Autosave Vault…with multiple copies. Defaults to every 30 min, and 25 copies. I change that to be every 10-15 min, as I accomplish a lot in 15 min. If you don’t press CMD-S often, nothing gets saved, not even the main project.
Shane
Little Frog Post
