Activity Forums Apple Final Cut Pro Legacy Crash on render
  • Crash on render
    Posted by Scott Davis on June 13, 2009 at 12:29 am
    I can not render anything over 2-3 minutes that doesn’t cause a crash. No warning; FCP just disappears and when I restart it goes to a default window set up. Only workaround is to baby sit the render and do it in small bits. I see others have had the same problem but there doesn’t seem to be any solution yet. Any ideas?
    PS-These are DV media and sequences with a lot of Motion Projects. Very little to no effects applied.
    Thanks in advance,
    Scott
    MacPro Quad 2.8
    ATI Radeon HD 2600
    4G RAM
    OS 10.5.7
    QT 7.5.5
    FCP 6.0.5
    Kona 3
    CalDigit HDOne
    Jason Levy replied 17 years, 2 months ago 6 Members · 9 Replies
  • 9 Replies
  • David Roth weiss
    June 13, 2009 at 1:52 am
    Here’s my list if things to do in order of priority:
    Trash Prefs
    Fix permissions in Disk Utility
    Run Disk Warrior on all drives especially your CalDigit HDOne (yes they recommend DW)
    Use the Render Manager to delete all renders for the current project
    If these don’t work, open a new project and move current timeline to the new project, try to render now.
    If that doesn’t work, cut and paste everything from the present timeline into a new timeline in teh new project.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Aaron Neitz
    June 13, 2009 at 2:01 am
    Rendering the Motion Projects in FCP?
    I had so many problems with that workflow, I would render out in Motion as a quicktime and bring it into FCP.
  • Scott Davis
    June 13, 2009 at 2:18 am
    David, thanks for the response.
    I had already:
    -trashed prefs
    -repaired permissions
    -dont have DW so haven’t done that
    -haven’t tried this in a new project yet will try that though
    -yes, tried the cut and paste
    So, I will try point 4 and see if that work.
    Scott Davis
    View Scott Davis's profile on LinkedIn
  • Scott Davis
    June 13, 2009 at 2:34 am
    So far nothing has worked. I think it is all the Motion projects.
    Scott Davis
  • Alan Lacey
    June 13, 2009 at 5:31 am
    Like Aaron, I’ve had endless problems leaving the motion projects on the timeline. I always render them separately now.
    Alan
    XDcamHD,XDcamEX,D9
    FCS,AE,Combustion,LiquidSilver,Vegas
    G5,MBP,XP
  • Jason Levy
    June 13, 2009 at 1:52 pm
    Sounds to me like you are running out of memory. Try bringing just the one sequence in to a new project and open it fresh with no other project running, then render and see what happens. I assume you have ample memory in your system… (more then 4 gigs does not help though.)
    Good luck.
    jason
  • Scott Davis
    June 13, 2009 at 2:48 pm
    Hi Jason, I thought the same thing. I have 4G of RAM, and tried it with nothing running other than FCP. I can render hour long projects easily when there are no Motion projects in them. At this point I believe it is the Motion projects. In a 40 minute piece we have 100+ Motion projects. For the online I will render out and bring them in as QT. I don’t want to do that now as the editor might still be making changes as we wrap the rough.
    Scott Davis
  • Jaap Verdenius
    June 13, 2009 at 9:15 pm
    Have you tried decreasing RAM allocation for FCP ? I know it sounds counterintuitive but I have always been wondering if Motion may be running in the background in these situations, desperate for memory
  • Jason Levy
    June 14, 2009 at 12:59 am
    Actually since final cut and motion have to run at the same time maybe more than 4 gigs would be helpful.. If you run Activity Monitor when you are trying to do this render how much free memory does is say you have available?
    jason
