Activity Forums Adobe Premiere Pro Crash on MPEG export
  • Crash on MPEG export
    Posted by Paul Budline on July 3, 2013 at 11:32 am
    A problem that is bad and seems to be getting worse – exporting to MPEG2, MP4, or M2V (DVD) always leads to a crash and the dreaded blue screen. Exporting to other formats is generally okay, but being able to use the above three is extremely important. The crash occurs whether using direct “export” or “queue” … on CBR, VBR, one-pass, two-pass, with or without “use previews,” with or without “use maximum render quality.” It sometimes happens deep into the export, at other times just as the export is beginning. I have monitored the core temps during export and they seem reasonable, rarely getting above 70 C. In this case I am exporting standard definition, but the same thing happens with HDV.
    Premiere Pro 6.0.3, Media Encoder 6.0.3.1, Windows 7 Professional 64-bit with Service Pack 1, 16 GB RAM, Intel Core i7-3930K 3.20GHz, overclocked (I believe.) NVIDIA GeForce GTX 680 with a recently-updated driver (this also occurred with the previous driver) The system was assembled by a very smart computer guy; unfortunately, he is not an Adobe expert and is a couple of hours away. His initial thoughts were temperature, but that seems to not be an issue.
    I would re-install Media Encoder, but it seems an embedded part of Premiere Pro CS6. And I’ll certainly re-install PP if that might help, or perhaps can revert to an earlier version of Media Encoder. Before going to those steps, I wonder whether anyone else has run into a similar issues and might have a suggestion. Thanks very much.
    Paul
    Ericbowen replied 13 years, 2 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    July 3, 2013 at 4:30 pm
    Bluescreen crashes are usually hardware related. Google how to diagnose these issues and you may find it’s because of a bad hardware driver (you may need to roll back 3-4 versions), bad ram, overheating, and so on.
    I would turn overclocking off in BIOS. I’m running i7 2600K and noticed some RAM voltage issues that lead to bluescreen crashes so I had to dial down settings quite a bit from what I, initially, found stable.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Paul Budline
    July 3, 2013 at 5:40 pm
    Either my computer maker is a genius or I’ve been getting very lucky. He had me go into BIOS and turn up one voltage parameter by some small amount … encoding has gone very smoothly since then. Definitely hardware.
  • Ericbowen
    July 9, 2013 at 8:27 pm
    MPEG encoding requires conservable processing through the CPU pipeline and memory management for repeated use of data. When ever you have crashing specific to those exports, its CPU or ram. In this case the CPU voltage was to low at load which is harder to see in today’s platforms because of all of the power management and cpu state changes.
    Eric-ADK
    Tech Manager
