Activity Forums VEGAS Pro Crash on importing files – unmanged exception
  • Crash on importing files – unmanged exception
    Posted by Ibrahim Mehmet on April 14, 2011 at 5:30 am
    Importing errors – Unmanaged Exception (0xc0000005)
    I get these exception errors when I am trying to import Sony MXF files Full HD. I am keeping my media on a network drive and seems it cannot keep up. used to work fine before.
    Any suggestions please?
    Quadcore machine 2.67 Ghz i7 920
    12 Gigs of Ram
    Nividia graphics card
    Ibrahim Mehmet replied 15 years, 5 months ago 2 Members · 4 Replies
  • John Rofrano
    April 14, 2011 at 12:44 pm
    [ibrahim mehmet] ” I am keeping my media on a network drive and seems it cannot keep up. used to work fine before.
    Any suggestions please?”
    Copy the file locally. This has the advantage of using the network drive as a backup/archive and the local copy as a “sandbox”. I have a 1TB RAID 0 where I do all of my work locally and it performs very well.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ibrahim Mehmet
    April 16, 2011 at 3:58 am
    thanks John I will try that,
    Another issue is, when I have vegas open and working etc everytime i jump out to another app like photoshop or even just looking thru my folders on my drives WHEN I JUMP BACK IN BY CLICKING ON THE VEGAS panel vegas takes AGES (SLOW) to respond to my command.
    Does anyone else have this issue???
  • John Rofrano
    April 16, 2011 at 2:55 pm
    [ibrahim mehmet] “WHEN I JUMP BACK IN BY CLICKING ON THE VEGAS panel vegas takes AGES (SLOW) to respond to my command.”
    It sounds like you might have your media on slow drives. By default, Vegas closes all the file handles when it looses focus so that you can work on files in another application. The delay you are seeing (which I’ve never experienced because I always work on RAID 0 drives) is Vegas opening all the file handles again to see what may have changed.
    If you want to disable this go to Options | Preferences | General and uncheck:
    [_] Close media files when not the active application
    [_] Close audio and MIDI ports when not the active application
    This should fix your problem but understand that you will NOT be able to edit an image in Photoshop that Vegas is using on the timeline after making this change.
    ~jr
  • Ibrahim Mehmet
    April 17, 2011 at 3:26 am
    Thanks again John
    I will try and get back to you later.
    Cheers
