Activity › Forums › Apple Final Cut Pro Legacy › crash on export
  • Nicole Haddock
    November 23, 2009 at 7:16 pm
    I think if I could take away one feature of FCP, it would be the QT Conversion option.
    Export to Quicktime, then do whatever compression you need.
  • Jack Blandford
    November 23, 2009 at 7:41 pm
    Is there another way to export a still then?
    thanks
    jack
  • John Fishback
    November 23, 2009 at 8:00 pm
    What Nicole says, then use Compressor to encode. It’s faster, too.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • John Fishback
    November 23, 2009 at 9:38 pm
    It’s possible that part of the the media you’re trying to export is corrupt. Try exporting a different frame. What exactly is your export workflow. What type of still are you trying to export?
    John
  • Nicole Haddock
    November 23, 2009 at 9:40 pm
    You can do a standard screen grab and then crop it down in Photoshop- Apple+Shift+4 which then gives you a cross hair to drag around whatever you want to capture. File will show up on your desktop in TIFF, PDF or PNG format.
