Activity › Forums › Boris FX Particle Illusion › Crash on export to QuickTime
  • Crash on export to QuickTime
    Posted by Grete Hjorth-johansen on April 16, 2008 at 10:14 am
    I am a using ParticleIllusion 2.0.1 SE, and when i try to output a QT movie the application crashes! Help!! I’m on MacBook Pro using QuickTime 7.0.4. It’s a fairly old version of QT, is that the reason? I can’t upgrade QT yet due to incompatibility with other apps. ParticleIllusion works fine otherwise, and used to work before with QT, but I haven’t used it for a while and really need it for something now 🙁
    Any advice would be greatly appreciated!
    Alan Lorence replied 18 years, 5 months ago 2 Members · 1 Reply
  • Alan Lorence
    April 16, 2008 at 12:29 pm
    If it crashes with every compressor you try, and with all stage sizes (even 320×240 as a test), then I suggest a couple of things:
    1) render a PNG image sequence instead of a QT movie
    2) email support at wondertouch dot com with your problem and I’ll send you the beta version of 2.0.2 to see if that helps.
    Alan.
    http://www.wondertouch.com
