Activity Forums AJA Video Systems crash on capture
  • crash on capture
    Posted by David Go on August 3, 2005 at 11:48 am
    Hi everybody,
    Just having some problems with my new Kona LS, FCP 5, Tiger, G5 dual 2.3 set up. It basically gives me the beach ball of death most times I open the capture window. We’ve gone through a whole heap of trouble shooting, including changing raid discs, cables, upgrading software and drivers and even replacing the actual G5 (which was originaly a dual 2, but I read a lot of people saying the 2’s are full of bugs).
    As far as I can see the only thing left is the card and the Digibeta deck that is still the same. We also have another identical setup with the same problem so I doubt that it is a dud card because both are having the same problem.
    Can anyone help? It’s driving me crazy.
    Thanks.
    David Go replied 21 years, 1 month ago 2 Members · 2 Replies
  • Berenger Capmany
    August 24, 2005 at 10:34 pm
    I have the same problem, but only when I choose a specific easy setup… 1080i/50 the rest of settings works perfect.
    Sometimes, a mismacth in the capture settings lead into a crash.
    verify the capture settings…
    drop preferences..
    cheers!
  • David Go
    August 24, 2005 at 11:16 pm
    Thanks.
    We’ve soughted the problem out. It seems Kona were a little too eager to release a new driver and there is a conflict with FCP 5. We’ve gone back to the previous Kona driver and it works perfectly.
