Activity Forums Adobe After Effects Crash at end of render
  • Crash at end of render
    Posted by Clayton Light on June 13, 2008 at 5:03 pm
    My render seems to be going fine, then I get a window saying that a copy of my project was saved. When I click okay I get a beach ball and I must force quit. When I try to open the movie, it has a quicktime icon but I get a window that says it’s not a movie. Is this a common problem?
    MacPro quadcore 3gHz. OS 10.5.3. Quicktime 7.5.
    Clayton Light replied 18 years, 3 months ago 2 Members · 2 Replies
  • Kevin Camp
    June 13, 2008 at 5:58 pm
    there was a render problem with cs3 and 8-core systems that was fixed in an update (8.0.2 is the latest). so make sure you have the latest version…
    there was also a post a week or two ago with similar issues… the problem was traced back to an older piece of audio hardware. if that device was disconnected, ae rendered fine. what kinds of extra hardware do you have (video/audio capture devices, etc)?
    also, do you experience this problem rendering to all codecs/formats or just one specific one? and do you experience this if you were to ‘export’ the file as, say a dv stream, rather than render?
    and, one last thing, has it always been an issue, or is this something new? if it is new, you might try running the disk utility (applications/utilities) and repair permissions and verify disk. maybe even remove the ae pref file folder (users/[username]/library/preferences/adobe/after effects). move the folder with the version number (like 8.0) to the desktop, start ae and try a render again.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Clayton Light
    June 13, 2008 at 9:40 pm
    Trashing the prefs did the trick.
