Activity › Forums › Adobe Encore DVD › Crash after 20min of “Building”
  • Crash after 20min of “Building”
    Posted by Yen Condeelis on December 8, 2007 at 7:49 am
    I have Encore CS3 I have one 20 min time line and then 9 slide shows. (Image size is 2816 x 2112 ) I have 1.68GB space left in this project. (about 1/4 left of the blue bar on the Build tap)
    My show will burn just fine IF I only have 7 side shows BUT when I add the next two it will build or burn for like 20 minutes and then Encore crashes. I have tryed it 3 times now and it crashes all 3 times. Before I do a build I “Check Project” and ALL is well. Any idea’s as to what is going on and HOW I fix it?
    THANKS!!!
    Heath Firestone replied 18 years, 9 months ago 2 Members · 1 Reply
  • Heath Firestone
    December 11, 2007 at 2:41 am
    Not quite sure, but you might try scaling your slideshow images down to a more manageable resolution in PhotoShop or whatever graphics program you are using. See if that solves your problem.
    Heath
