Activity Forums Blackmagic Design Crakly audio on initial Play
  • Crakly audio on initial Play
    Posted by Aaron Neitz on February 22, 2007 at 5:52 pm
    I’ve been getting this intermittent problem in FCP – when I hit play, sometimes the audio is a little crackly and drops out for a second or two, and then locks in and plays fine. Sounds like a piece of hardware isn’t decoding the digital stream quickly enough.
    I’m working in primarily 2 channel stereo 48k timelines.
    BM HDplus 5.8
    Dual G5
    FCP 5.1.2
    Flying Cow hooked up to the RCA SPDIF from BM and then I switch used a balancing converter and put in the AES in (problem persists).
    Jeremy Brettingham replied 19 years, 6 months ago 4 Members · 5 Replies
  • Kristian Lam
    February 23, 2007 at 12:14 am
    This should be addressed in an upcoming driver update.
    regards
    Kristian Lam
    Blackmagic Design
  • Aaron Neitz
    February 23, 2007 at 1:03 am
    Ah…. any idea when? It’s a bit embarrassing when you’re playing back final sequences with clients in the room…
  • Kristian Lam
    February 23, 2007 at 2:44 am
    Don’t have an eact date but I think it should be sometime next week as you can tell from our past release dates.
    regards
    Kristian Lam
    Blackmagic Design
  • Anthony Dalesandro
    February 27, 2007 at 12:54 am
    We’re getting the same thing. Glad to hear a fix is in the works.
    Anthony Dalesandro
    add2@pacbell.net
  • Jeremy Brettingham
    February 27, 2007 at 9:38 am
    I’ve always thought that this was a problem of having the ‘stop playback on dropped frames’ unchecked. My way round is to make sure when I’m playing back just to give a 5 sec run up. It usually happens when you start playing audio from say half way through a fade in or when it’s part of a rubber-banded clip. Similar thing happens on Avid you may be pleased to know!
