Activity Forums Adobe After Effects Cracked glass effect to 3d Layer
  • Cracked glass effect to 3d Layer
    Posted by Chrishoare2003 on September 1, 2006 at 10:46 am
    Hi
    I have some text that currently begins in the distance and quickly races towards the screen. I want the text to appear to smash into the screen, thus cracking the screen. I have tried displacement mapping but this does not seem to achieve the effect i require. Anyone have any suggestions?
    Mike Clasby replied 20 years ago 2 Members · 2 Replies
  • Mike Clasby
    September 1, 2006 at 5:49 pm
    This from Aharon recently for a cracked wall, might be just what you want:
    Name: Aharon Rabinowitz
    Date: Aug 18, 2006 at 11:05:22 am
    Subject: Re: Animating cracks ? + realistic camera shake.
    Try shattering a layer with the effect called Simulation > Shatter.
    Set the shape to Glass
    Set the viscosity all the way up to 1
    Set the Gravity to 0
    May not be waht you want, but maybe…
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Mike Clasby
    September 1, 2006 at 7:09 pm
    As a nice addition to Shatter (glass), I just did an autotrace (work area, low numbers for Tolerance and Thresold) of the layer shattered.
    To get a nice light flash that leaks from the cracked screen I added:
    Vegas
    Stroke: Image Contours
    Segments 1
    Width up to 6 or so
    Color-light blue or your version of electric short
    Rendering>Blend Mode>Transparent
    CC Radial Fast Blur
    Amount 100
    Zoom Brightest
    Then just cut off the layer, Alt + ] when you want the flash to get. Add a wiggle to the opacity to get a flicker.
