CPU’s and GPU’s what is doing what at what stage…?
Matt Dunphy replied 11 years, 5 months ago 6 Members · 15 Replies
Sonic 67
March 9, 2015 at 1:03 pm[Stephen Mann] “There’s nothing in the GPU API that tells it how to do simple computing, like 1+1.”
You are horrible wrong. The present day GPU’s are actually full feature CPU’s, with massively parallel cores. They can be programmed in C++ like any CPU, do floating point calculations single or dual precision, used in heavy scientific work…
They are even the base of several of the top supercomputers (nVidia Tesla, AMD). -
Stephen Mann
March 9, 2015 at 1:42 pmI said there’s nothing in the GPU API. Not the GPU. The supercomputers using GPU’s massive parallel processing don’t use the same drivers that are used in video processing.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Norman Black
March 9, 2015 at 7:39 pm[Stephen Mann] “There’s nothing in the GPU API that tells it how to do simple computing, like 1+1. But point it to the data for a series of frames and ask it to compress them into a GOP, then it’s right at home. Theoretically faster than the complex CPU.”
Wow. Educate yourself please.
Matt Dunphy
March 26, 2015 at 6:44 pmIn 2013, I upgraded to Vegas 12, got a new computer & a video card specifically to utilize GPU-assisted rendering.
In my experience, enabling the GPU actually resulted in slower render times. Whenever effects were being rendered, my CPU’s usage would drop from 100% to a fraction of that, presumably having the computer send all the work to the GPU. Maybe it’s helpful if you’ve got an older processor, but ultimately, I felt like I’d blown a couple hundred bucks on an unnecessary video upgrade. Live n’ learn.
