Activity Forums Maxon Cinema 4D CPU vs GPU
  • CPU vs GPU
    Posted by Matiss Jansons on July 15, 2020 at 8:42 am
    I just noticed that when rendering with Maxon Cinema 4D S22, my CPU is being used and not GPU and it takes forever to render an image.
    Is there any way to switch it up in some settings in Cinema 4d or my Windows 10 settings to use GPU instead?
    I’m using Dell XPS, 2019.
    Any advise is highly appreciated!
    Regards,
    Matiss
    Matiss Jansons replied 6 years, 2 months ago 2 Members · 2 Replies
  • Brian Jones
    July 15, 2020 at 4:24 pm
    The Standard and Physical rendering engines are CPU based, they were programmed to use the CPU and would have to be rewritten to use the GPU. The ProRender engine uses GPU, Redshift uses GPU as do a number of other available renderers.
  • Matiss Jansons
    July 16, 2020 at 12:09 pm
    Thanks a lot for the info!
    Much appreciated!
