Activity Forums Adobe After Effects CPU usage in a script process
  • CPU usage in a script process
    Posted by Xavier Gomez on August 2, 2012 at 1:28 am
    When i run a .jsx script in AE my CPUs are very much underused (only 2 out of 8, and not even at full load) and i’m wondering if that’s a normal feature. It really feels like a big waste, only 12% cpu usage, lots of RAM available, and the script takes ages to run.
    (When rendering a comp with the AE Render Engine, everything is fine, all cpus are fully used).
    Any advice welcome !
    Note: the script is generating a path over time, it doesnt modify the pixels of a footage item (so that might be the reason).
    Xavier.
    Xavier Gomez replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
