Activity Forums VEGAS Pro CPU usage
  • CPU usage
    Posted by Martin Phillips on June 11, 2009 at 6:47 pm
    I have noticed that my PC doesn’t refer as fast as it should (this tested with a friend with a similar pc). My pc is a quad core 2.6 with 4 gb ram. When my friend is rendering (same template settings) his CPU usage (seen in performance tab in task manager) is at 95%. On my pc it only gets to 30-32%. Can anyone help me get more out of the CPUs (there doesn’t seem to be any other processes eating up CPU) martin
    Martin Phillips replied 17 years, 1 month ago 2 Members · 2 Replies
  • Harold Brown
    June 16, 2009 at 12:13 am
    Do you have Vegas setup to use all 4 cores of your CPU? You did not mention what machine your friend has or the time difference between renders. What effects are you using in your project. Many things impact CPU usage.
    Harold
    __________________
    http://www.BhagaVideo.com
    Check out my published DVDs at
    http://www.edellismagic.com/Previews.html
  • Martin Phillips
    June 16, 2009 at 7:15 am
    Hi Harold and thanks for responding.
    My friends system is very simular:
    I have a 2.6 quad core with 4GB ram – he has the sale with 3GB ram. He uses vegas 8, im using version 7….
    It is set to 4, and all 4 are being used, but only at 30%, where his run at 95% when rendering MPEG2.
    Regards
    Martin
