Activity Forums Apple Final Cut Pro Legacy CPU upgrade compatability?
  • CPU upgrade compatability?
    Posted by Matt Short on June 24, 2005 at 7:09 pm
    I’m currently using Media100. I’ll be switching to FCP as soon as I finish the current project I’m working on. I just upgraded my G4 450 with a Sonnet 1.7ghz CPU. Turns out, M100 won’t launch with this upgrade. I pulled the CPU and re-installed the old one to get it to run. My question is, has anyone had any compatability issues with using a Sonnet CPU upgrade with the DecklinkSP card and FCP?
    Matt Short replied 21 years, 2 months ago 2 Members · 2 Replies
  • Derek Woods
    June 24, 2005 at 8:18 pm
    did you check to see if the g4 can “see” the new proccessor? go to the system profiler and check. There is a download from sonnet that has to be installed for the mac to see it. also if you installed a new system, you have to reinstall the download. hope that does it.
  • Matt Short
    June 26, 2005 at 10:56 am
    Everything works except for the Media 100 when the Sonnet is installed. I talked to Sonnet and M100 and apparently there are some issues with compatability.
