Activity › Forums › Apple Final Cut Pro Legacy › CPU question
CPU question
Posted by Tom Mooney on June 11, 2009 at 5:27 pmWe need to pick up another MAC for our off line editing suite. I want to still run the latest version of FCP on the computer. How far back can we go in purchasing a used G5. I see allot of 1.8 duel processors for sale and that would be fine. Most times the system would be editing footage digitized in Apple Pro Res. Thanks
Colin Mcquillan replied 17 years, 3 months ago 3 Members · 5 Replies -
Walter Biscardi
June 11, 2009 at 5:47 pm[Tom Mooney] “Most times the system would be editing footage digitized in Apple Pro Res. Thanks”
Then you don’t want a G5. ProRes is not supported on very many G5’s. Requires a LOT of CPU horsepower for that codec.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Tom Mooney
June 11, 2009 at 7:30 pmWe do have a MAC G5 2 dual processor that is over 3 years old and it does work with Pro Res no problem. That computer does have Kona LH card in it for rendering 10bit. Is that why it works? Thanks Walter.
Walter Biscardi
June 11, 2009 at 7:53 pm[Tom Mooney] “hat computer does have Kona LH card in it for rendering 10bit. I”
The Kona does nothing for rendering.
We could not get our G5 Dual 2.0 to work with ProRes at all.
The G5 Quad 2.5 with the Kona 3 in there works just fine.
Tom Mooney
June 11, 2009 at 9:57 pmThe one thing is we will only be using it for 720p at 30 frames, so it does make relatively small files. The 720P at 60 frames runs OK on our old G5 2 dual. We have a budget constraint for this system so I was looking to get something for under $500. Will do more homework.
Colin Mcquillan
June 12, 2009 at 8:26 am[walter biscardi] “We could not get our G5 Dual 2.0 to work with ProRes at all. “
I recently did a stretch of work on a system outside of my studio, on a dual 2.0 G5. The footage had already been captured to ProRes before i got there. Everything seemed to be OK for the first while, but when rendering, the clips from time to time would slip within their in and out point, yet keep the proper TC of the frame that should be playing. This happened most often when there was an overlay or dissolve over, or into the clip.
Recapturing the footage at 10bit worked like a charm and all jumped back into the proper place.
Colin McQuillan
Vancouver, B.C.
