Activity › Forums › Adobe After Effects Expressions › COW Tutorials: After Effects Scaling a Motion Path in After Effects
Posted by Kathlyn Lindeboom on January 13, 2006 at 3:24 am
&page=https://www.creativecow.net/articles/rabinowitz_aharon/scale_path/index.html”>Scaling a Motion Path in After Effects In this tutorial Aharon Rabinowitz shows you the secret to scaling a motion path in After Effects. If you’ve ever created motion in after effects that you needed to confine to a smaller area, but also needed to keep the exact same shape, this lesson will show you how you can easily do just that, through the use of After Effects’ layer masks.
Click on the link above to watch Aharon’s tutorial.
Kathlyn Lindeboom
Creativecow.netEric Lease replied 20 years, 8 months ago 5 Members · 12 Replies -
Andrei Firtich
January 13, 2006 at 4:59 amSweet tutorial, I have a question on the same theme. Is there a way to convert illustrator file that is exported into after effects into a mask shape w/o first opening it in illustrator getting your preferences right and copy, pasting it.
Thanks in advance, great job with tutorials, the z scale one was pretty sweet too 🙂 -
Aharon Rabinowitz
January 13, 2006 at 1:02 pmI don’t think so. post this in the regular AE forum, and maybe someone knows better. Pretty sure you have to open AI or PS tp dp this.
Aharon Rabinowitz
aharon(AT)yahoo(DOT)com
http://www.allbetsareoff.com
Creative Cow Master Series DVD
particleIllusion Fusion Volume 1
available @ http://www.pIllusionFusion.com -
Markval
January 13, 2006 at 3:47 pmyes you can.
1. In Adobe Illustrator, create your path, select all of the points along the path, and then choose Edit > Copy.
2. In After Effects, open the Layer window for the layer into which you want to import the path.
3. Choose Edit > Paste.Important: You must select the AICB option in the Files & Clipboard section of the Adobe Illustrator Preferences dialog box for this method to work.
Aharon Rabinowitz
January 13, 2006 at 3:48 pmhis question was how to do it without opening illustrator.
Aharon Rabinowitz
Aharon Rabinowitz
January 13, 2006 at 3:51 pmfor the record I’ve already submited a 4 minute tutorial on using illsutrator and photoshop to create motion paths and masks in AE, along with some of the issues that pop up when doing it.
However, once again, it requires that you open the programs.
Aharon Rabinowitz
Eric Lease
January 16, 2006 at 5:52 pmCool tutorial on using masks for paths (and vice versa), but for scaling, wouldn’t it be easier to parent to a null layer, then scale the null?
Aharon Rabinowitz
January 17, 2006 at 1:21 amthat would also scale the layer. Of course you could also inversely scale the layer to counter it – But only if if the scale atribute wasn’t already animated, and if only if you could figure out the exact amount to inversely effect the scale, so that it doesn’t change. Seems a lot easier to me this way.
Aharon Rabinowitz
Aharon Rabinowitz
January 17, 2006 at 2:48 pmplus, you can’t give the position data to any other layers or effects, or expressions, becasue it is still the original position data.
It’s not a perfect method, and like I said in my tutorial, neither is mine.
Aharon Rabinowitz
Eric Lease
January 18, 2006 at 12:33 amHow about this (much simpler than what I said before):
Go to first scale keyframe (or first frame if there are none). Note value of scale.
Parent to null.
Scale null.
Unparent from null.
Select all scale keyframes.
Drag scale value back to original (scrub, using command or alt to fine-tune).
All scale keyframes should scale proportionally, leaving you with just a scaled motion path.Whaddya think?
