Activity › Forums › Adobe After Effects Expressions › COW Tutorials: After Effects Creating Light Streaks
Joel Young replied 19 years, 1 month ago 12 Members · 16 Replies
Ronnie Zeemering
October 19, 2006 at 12:27 pmthank you so much for this (and most of your other tutorials!)
i went along and made a handwritten logo so i can use it while vj-ing in a club.
For this purpose (and others ofcourse) it would be nice to give it an alpha channel. If i ‘un-ey’ the BG layer i can export it with an alpha channel. But no colour can be seen. Applaying the color to the partical layer works but looks not as good as applaying to both the partical and BG layer.I tried several things but couldnt export with an alpha and with colour at the same time. Is there a handy way it can be done?thnx for anyones answer 😉
Ronnie
Morpher2k4
October 20, 2006 at 1:14 pmNice tutorial. I tried to recreate this effect in a very simillar way. I animated the pathway with keyframes and added also shine for more glowing. Tomorrow I will try the first tests with dancing people:
https://www.morpher.de/clients/works –> scroll all the way down to see what I got so far 🙂 -
Steve Morris
October 22, 2006 at 10:53 pmI was trying to put a person in behind the light streaks. I could not find a way to get the person to not be affected by the adjustment layer. I tried every possible way with pre-composing and many others ways.
I really just need one frame of video. I am using the streaks in a poster (made the comp 3,000 x 3,000). I thought I would be able to export an alpha rendered frame if I dropped out the background. When I dropped the background, I lost the color and glow. I got only white streaks. I want just the streaks and glow on an alpha channel to put into Photoshop.
How do I render out the streaks and glow as a single frame with alpha channel?
Steve Morris
October 22, 2006 at 11:02 pmI as able to export the white streaks and add the hue and saturation in Photoshop. The glow part does not look as good as it did in AE. I am still open to ways to export it properly from AE.
Ronnie Zeemering
October 24, 2006 at 9:39 amjups,
exactly the same thing here.
since people are able to put a coke bottle behind it. It must be possible. Are we missing out something?thnx
Joel Young
August 14, 2007 at 12:45 pmHello, great tut, and I know I’m a little late on this, but I was just having the same problem as RZeemering & stevem1928. So I came researching here on the forums. Didn’t find it, but started playing more and I’ve got something that worked for me. After you make your effect in a comp, leave it be and when you add the “swirlie” effect comp to another comp just change the mode to add, lighten, or any other one in that section. Going to try some other ways to get it to go behind and in front of things, but is doing what I want now.
Lman
