Activity Forums Adobe After Effects COW Tutorials: After Effects Creating Cool 3D Text
  • Minamismud
    December 7, 2006 at 10:21 am
    when i tried this and i turned my letters sidwaysi could se spaces between each layer. how can i fix this to make it look like the letters are solid?
  • Tyler Paul
    December 7, 2006 at 1:43 pm
    It’ll never get completely solid because the layers are still only 2d but you can certainly improve the look.
    Create the layer with the text and this expression to the anchorpoint
    thisComp.layer(index – 1).transform.anchorpoint – [0,0,.5]
    This’ll push your current layer .5 pixels behind the layer above it. Continue duplicating the layer to add depth. Instead of having to go through each layer to make changes just delete your duplicates, make your change, and reduplicate.
  • Dotan Baytman
    December 7, 2006 at 2:45 pm
    Thanx for the tutorial really cool 3D text
    i also tried duplicating the text in the first comp and the text gets a cool 3D look
    hope to see more tutorials
  • Andrew Kramer
    December 7, 2006 at 3:19 pm
    Cool Tip Tyler, I knew there had to be something to streamline this.
    Andrew
  • Minamismud
    December 8, 2006 at 3:53 am
    cool thanks for the tip
