Activity › Forums › Adobe After Effects › COW Tutorials: After Effects Creating a Hologram Look
  • Darby Edelen
    February 1, 2008 at 7:20 pm
    Just a quick note on the loopOut() expression. You don’t actually need to specify “type=’cycle'” in the parameters as this is the default:
    loopOut(type="cycle");
    is the same as:
    loopOut("cycle");
    which is the same as:
    loopOut();
    If anything, specifying type=”cycle” might very slightly, imperceptibly even, increase memory requirements as you’re creating a variable named ‘type’ to contain the value “cycle” before passing it to loopOut()… But the main reason I mention it is because it takes less time to type it out =)
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Steve Roberts
    February 1, 2008 at 8:52 pm
    Thanks, Darby!
    Steve
