Activity › Forums › Letters to the COW Team › COW Tutorials: After Effects Color Timing: Using Curves to Simulate Bleach Bypass
  • COW Tutorials: After Effects Color Timing: Using Curves to Simulate Bleach Bypass
    Posted by Kathlyn Lindeboom on May 24, 2005 at 8:03 pm
    In this quick tutorial, Filip Vandueren would like to share a technique he uses a lot which in Belgium is called ‘etalongage’ or color-timing. It’s a two step process which gets great results.
    Adobe After Effects
    Filip posted this tip in the AE forum, but we thought it was too good a tip not to be officially in the library as an article. So, if you haven’t already seen it, click on the link above to view this quick tutorial.
    Kathlyn Lindeboom
    Creativecow.net
    Kathlyn Lindeboom replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
